Mesh data Rate
csco11030279
Level 3
Level 3
hi all;
I have one RAP one MAP,I set the Bridge data rate to AUTO on both, how can I show the current data rate between them?
what is the MAX range I can space between the RAP and MAP in outdoor and open area ?
Thanks for the supports
Too late .. I guess, but for future references you can always use the WLC's CLI commands to view the current data rate:
 show ap bhrate <ap-name>
The GUI interface will also display the info:
Wireless > Access Points > All APs Click Detail. The Data Rate and Ethernet Bridging parameters are in the Bridging Information section.
