Virtual WLC large images installed but small image running
marc.groenen
Ok so i installed a few virtual WLC's with the following image "Cisco_AIR_CTVM_LARGE-K9_8_2_110_0".
I can see this image is also running in the VM/cloud environment.
But when i logon to the WLC's it says vWLC config: Small and only 200 AP's are supported.
I am going to try and upgrade it to 8.2.121.0 LARGE through the normal AES upgrade process but according to this site this shouldnt work.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-2/b_Virtual_Wireless_LAN_Controller_Deployment_Guide_8-2.html#concept_D01C165C662E42AEA3D829A1285272D4
So i am not getting my hopes  up.
Did i miss something else ?
Feature
Benefits
Scalability
Small Scale Image:
  Supports 200 access points
  Supports 6000 clients
Large Scale Image:
  Supports 3000 access points
  Supports 32,000 clients
marc.groenen
Upgrade does not work i get the message: Transfer failure images is not for this model
I just redeployed with the image AIR_CTVM_LARGE-K9_8_2_121_0.ova this shows the correct supported AP's and also Large config.
