VLAN assignment without ACS on Cisco Wireless Controller 5508
rhap4boyz
I was wondering if it is possible to do dynamic VLAN assignment on the Cisco Wireless Controller 5508 without using Cisco ACS but use Microsoft NPS server instead?  Is there a manual or article that someone can point me in the right direction?
Thank you!
Stephen Rodriguez
Yes, this can be done.  NPS needs to be configured to return attributes 64/65/81
and here you go on that doc
http://technet.microsoft.com/en-us/library/cc772124(v=ws.10).aspx
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Amjad Abdullah
Any RADIUS server will allow you to do the dynamic vlan assignment if you configure the right RADIUS attributes (64, 65 and 81 that Steve mentioned above).
This doc shows example of dynamic vlan assignment with WLC and ACS.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
Same config on WLC is needed. However, on the RADIUS you need to configure the same attributes on the NPS instead.
Amjad
Rating useful replies is more useful than saying "Thank you"
Scott Fella
Here is a better guide to follow.... in this guide, he explains the different radius attribute to use on NPS and how to set it up.
https://lavazzza.wordpress.com/2010/05/29/wlc-school-for-network-admin%E2%80%99s-who-can-read-real-good-part-2-ok-so-it-has-been-awhile/
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
