vlan concern
yogesh1
Level 3
Level 3
HI Everyone,
If we have configured two vlan 50, 51 both with d/f ip range as mention below in core switch
interface Vlan50
ip address 10.85.49.1 255.255.255.0
no ip redirects
no ip unreachables
end
nterface Vlan51
ip address 10.85.93.128 255.255.255.128
no ip redirects
no ip unreachables
end
and we already pass vlan 50 in our access layer switch where system already getting ip so if we also pass vlan 51 in that switch like switchport access allowed vlan 51 so in that case end system is getting ip from which range please let me know..?
Hi @yogesh1
 Not sure if I understood but if this two vlan were extended to the WLC, assuming you are talking about that, then, you can create a interface group, put those two vlans and WLC will allow clients get IP from two vlans.
   If you are not talking about a PC then either it uses one or other as it has only one dhcp server option.
-If I helped you somehow, please, rate it as useful.-
