VLAN Help 1240AG
rmwhite59
Need a secure and unsecure SSID
I create my SSID's, assign vlans
The only way it works is if the SSID is on the native VLAn
I have my switchport trunking the vlan's
mirek.tichy_2
try something like below. VLAN 11 is secure with 802.1x EAP security, VLAN 22 is insecure, VLAN 33 is only for management of the AP. On the switch is set up as native but it isn't propagate by the radio. Hope this help.
MiTi
aaa new-model
aaa group server radius acs_praha
server 10.10.10.10 auth-port 1645 acct-port 1646
aaa authentication login default group acs_praha local
aaa authentication login method_client group acs_praha
aaa authentication login method_local local
aaa authorization exec default group acs_praha if-authenticated
aaa authorization exec method_local local
aaa session-id common
dot11 ssid wifi1
vlan 11
authentication open eap method_client
authentication network-eap method_client
authentication key-management wpa
dot11 ssid wifi2
vlan 22
authentication open
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 11 mode ciphers tkip
ssid wifi1
ssid wifi2
bridge-group 1
interface Dot11Radio0.11
encapsulation dot1Q 11
bridge-group 11
interface Dot11Radio0.22
encapsulation dot1Q 22
bridge-group 22
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.11
bridge-group 11
interface FastEthernet0.22
bridge-group 22
interface FastEthernet0.33
encapsulation dot1Q 33 native
bridge-group 1
interface BVI1
ip address 10.0.0.10 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.1
radius-server host 10.0.0.11 auth-port 1645 acct-port 1646 key mysecret
bridge 1 route ip
