VLAN issue
echelon360
Level 4
Level 4
I have a vlan that has been defined on my core switch with the following config
interface Vlan50
description WLAN
ip address xx.xx.xx.xx xx.xx.xx.xx
on the controller, WLAN interface has been created referencing the above mentioned
On my core switch, i have connected gi4/41 onto the controller. I have defined this as a trunk port.
Config:
interface GigabitEthernet4/41
description *AP Controller*
switchport mode trunk
speed 100
duplex full
I am able to ping this vlan ip on my core switch.However, i am not able to ping the vlan ip from the controller?
any ideas?
irisrios
Level 11
Level 11
This is a normal behaviour. On the controller the management interface is the only consistently pingable interface. All other dynamic interfaces will not be pingable.
