VM WLC not passing traffic to the LAN
Mark Hazell
Hi all,
I have an issues with a VM WLC running ver 7.4 in that I get dhcp from a central server for the SSID but once I have this I am not able to talk to the LAN. The wlc can ping devices on the LAN fine but the wireless clients can't. The clients can only seem to pint the wlc.
An ideas would be great. Thanks in advance.
8 Replies 8
David Watkins
Level 4
Level 4
Is the WLAN using your management network?  If not, are you tagging or untagging the dynamic interace?  Does the ESX VM network allow ALL VLANS 4095 and is your trunk port to the ESX host permitting this dynamic interfaces VLAN along with appropriate tagging for native/etc?
Mark Hazell
Hi David,
Thanks for the reply, I currently have the SSID set to the management interface.
I am going to redeploy the VM today to see if I have missed anything during the build. As the management interface can connect to the network and I can browse to the vm wlc fine.
Mark Hazell
All fixed rebuilt the vm today and the problem has now been resolved.
Thanks for the response David
Hi Mark,
can you please tell me what was missing in the configuration?
Mark: +5 for resolving your own issue.
Rating useful replies is more useful than saying "Thank you"
msonnie
Please also check ACL on the WLC, which is usually the issue for communication errors.
sahseth
Please check basic routing and NIC teaming on VM.
Thanks.
Mark Hazell
Hi all,
The problem was due to the vm nice not being setup correctly for service port ad data port. This led to strange arp problems
Which was stopping traffic from traversing the LAN
