Vocera one way audio or dropped calls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-01-2009 05:26 PM - edited 07-03-2021 05:05 PM
<p>We have a small Vocera deployment and just upgraded to Vocera version 4.1 and are seeing one way audio or dropped calls. We are not running an LWAPP solution yet and our Access Points are version 12.3(4)JA. We have verfiied that the badges are not roaming and aren't lossing connectivity to the access point. And they work fine when you play the welcome tutorial, it just seams to be badge to badge calls.</p>
<p>I was wondering if anyone has seen this before and gotten a resolution.</p>
<p>Thank You</p>
- Labels:
Wireless IP Voice and Video
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2009 05:27 AM
check to see what your power levels on the ap's are set to. The badges can only transmit at 30 mw, and if your ap's are set to transmit at 100mw, you will create one way audio because the badge can still recieve audio from the ap, but the ap can't receive from the badge.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2009 05:50 AM
Yes, I am transmiting at 100mw, what should I set it to? I have never had to change this before. But, I'll give it a shot.
Thanks for the help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2009 06:28 AM
depending on your coverage, it would be optimum to set the ap's to 30mw, but that will reduce the coverage area. We have the majority of our ap's set to 30mw, with a few set to 50mw.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2009 11:04 AM
Are you limiting client power at all via the AP?
