voice and minimum rssi
wyfy-2015
Level 3
Level 3
According to other vendors  the minimum rssi required  for voice is - 65 dBm and as per the cisco it is my -67 dBm
Any  ideas ?
Ric Beeching
Level 11
Level 11
See this link:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan41dg-book/vowlan_ch1.html
Yes Cisco recommends -67 instead of -65 if you're using their equipment. If mixing or using other vendor equipment you should design for their recommendations.
Cheers,
Ric
Please rate helpful / correct posts
mohanak
Typically voice networks require a -65db or better signal level, while a data network needs -80db or better signal level.
Leo Laohoo
1.  -65 dBm is a stronger signal to -67 dBm.
2.  It is easier for some to memorize -65 dBm than -67 dBm.
