voice over wireless calc
borovac
Visitor
Can someone give one example about calculation
parameters for use voice over wireless ?
Is this equal to voip over ethernet or not
So for 7920, can have up to 7 on call simultaneously per AP. # of APs depends on environment, # of clients, etc. Need to have a certified partner do a wireless site survey.
Sorry for imprecise question ?
My question is for WAN link between two sites, not
local telephony ? How to treat this for calculation as voip on Ethernet, voip on ppp, or what ? Are there any differences in calculating overhead over
wirelles wan link ?
Ok, so no real direct connected clients then. Should be very similiar. I would recommend 802.11a here though, which would be the 1400 bridge.
