vWLC and IPSK
metzleran
Frequent Visitor
Frequent Visitor
Does anyone know if IPSK is supported on the virtual WLC platform? I know it's implemented in version 8.5, but I don't see anything on support for vWLC.
5 Replies 5
Sandeep Choudhary
Its supported if your vWLC has SW version 8.5  or higher.
Dont forget to rate helpful posts
Leo Laohoo
iPSK is supported in ISE 2.2 and WLC firmware 8.5.130.0 and later.
metzleran
Frequent Visitor
Frequent Visitor
vWLC only supports Flexconnect APs and IPSK requires local mode. So, it isn't supported on the vWLC platform.
That is incorrect, iPSK can work on Flex or Local mode APs.
Ric
Please rate helpful / correct posts
I was working off this:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_Identity_PSK_Feature_Deployment_Guide.html
which has these conclusions:
  • IPSK is not supported on the Flex Connect locally switched mode. AAA server is required with AV-Pair support.
  • IPSK is not supported on the Flex Connect Group.
