vWLC issue!!
saboodi
I installed vWLC in my lab but my question is this controller support OTAP or not??
2 Accepted Solutions
Sandeep Choudhary
As per my knowledge... OTAP is no longer supported on the controllers with 6.0.196.0 and later releases.
Dont forget to rate helpful posts
omz
The OTAP feature is enabled on the controller GUI from the controller General page or through the CLI with the config network otap-mode {enable | disable} command.
This feature is disabled by default and should remain disabled when all access points are installed.
OTAP is no longer supported on the controllers with 6.0.196 code and above.
Sandeep Choudhary
omz
