Wall mount bracket for AIR-ANT5160V-R
Sylvain Vasseur
Hi all,
I am looking for a wall mount bracket reference, for these 2 models of antennas :
- AIR-ANT5160V-R
- AIR-ANT2506
Something like that :
I was not able to find any reference in cisco product list. Does anyone have an idea ?
Thank you
No its not part of there list... I though you already has these mounts.  I would just go buy it from another antenna manufature vendor... it will be cheaper:)
http://www.amazon.com/WLanParts-Antenna-Wall-Mount-Bracket/dp/tech-data/B002T0G8TQ
-Scott
9 Replies 9
Scott Fella
You still can use that mount that you have in the picture... you just need to use the mounting strap or a u-bolt to mount the antenna to that particular mount that you are showing.  Make sense?
-Scott
Hi Scott,
Thanks for your reply.
The picture I am showing is an example of what I have seen.
I am going to deploy lots of wireless sites, that's why I am looking for a reference of wall mount bracket I could buy to deploy easily the outdoor antennas.
It seems this accessory is not part of Cisco's product list ?
-Scott
Thank you, I have to check if the diameter is correct. But yes, it wil be cheaper !
There was another company when I googled antenna mounting bracket that sold that mount for 6 dollars.
Scott Fella
Sent from my iPhone
-Scott
Here is one for 5.80 each
http://www.wlanparts.com/product/WMB/WLanParts-Antenna-Wall-Mount-Bracket.html?meta=GBASE&metacpg=WMB&utm_source=gbase&utm_medium=CPC&utm_content=&utm_campaign=WMB
-Scott
thank you !
Derrick Robba
Try www.terrawave.com, if you can't find local..
thanks
