WAP reboot due to crash
Manish Manwal
we have wlc 9800 and having multiple AP connected to it. sometime we get the logs that wap reboot due to crash. can anyone help. WAP model: CW9166I-B
Jan 22 23:23:30.901: %APMGR_TRACE_MESSAGE-3-WLC_AP_LOG_MSG: Chassis 2 R0/0: wncd: AP Remote Log: 087b.87a9.xxxx Last AP wap08 reboot was due to crash
THANKS
MANISH MANWAL
19 Replies 19
Show process cpu sorted
Show process cpu plat sorted
Share output of both
MHM
WLC#sh processes cpu sorted
CPU utilization for five seconds: 43%/2%; one minute: 5%; five minutes: 3%
--More--   PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
393 141119921 15573811 9061 26.68% 2.63% 1.55% 0 SNMP LA Cache pr
738 99320037 82308059 1206 7.35% 1.15% 0.94% 0 SNMP ENGINE
93 37555064 104293010 360 5.99% 0.61% 0.37% 0 IOSD ipc task
737 3409700 67795253 50 0.23% 0.03% 0.00% 0 PDU DISPATCHER
651 4787342 135199062 35 0.23% 0.05% 0.04% 0 IP SNMP
736 1022410 48856997 20 0.07% 0.01% 0.00% 0 ONEP Network Ele
756 38 87 436 0.07% 0.02% 0.00% 2 SSH Process
148 3390539 602447086 5 0.07% 0.02% 0.01% 0 L2 LISP Punt Pro
164 328582 9786298 33 0.07% 0.00% 0.00% 0 Per-Second Jobs
144 2365117 72001965 32 0.07% 0.02% 0.00% 0 IOSXE-RP Punt Se
190 500867 76288153 6 0.07% 0.00% 0.00% 0 MCP RP autovc pr
--More--   12 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
13 0 2 0 0.00% 0.00% 0.00% 0 Timers
11 9962 163104 61 0.00% 0.00% 0.00% 0 Pool Manager
15 0 1 0 0.00% 0.00% 0.00% 0 MEMLEAK PROCESS
16 1739167 26242356 66 0.00% 0.01% 0.00% 0 ARP Input
10 8812590 1653890 5328 0.00% 0.11% 0.06% 0 Check heaps
14 653 119656 5 0.00% 0.00% 0.00% 0 WATCH_AFS
17 93434 10205712 9 0.00% 0.00% 0.00% 0 ARP Background
20 4 193 20 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
21 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
22 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
23 1842 33041 55 0.00% 0.00% 0.00% 0 Entity MIB API
24 113 116 974 0.00% 0.00% 0.00% 0 PrstVbl
18 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
26 49968 4892565 10 0.00% 0.00% 0.00% 0 IOSXE heartbeat
19 0 1 0 0.00% 0.00% 0.00% 0 ATM ASYNC PROC
28 64666 9786196 6 0.00% 0.00% 0.00% 0 GraphIt
29 0 3 0 0.00% 0.00% 0.00% 0 DB Notification
9 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
31 0 2 0 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
32 5 147 34 0.00% 0.00% 0.00% 0 IPC Apps Task
33 2 31 64 0.00% 0.00% 0.00% 0 ifIndex Receive
34 9176 1957160 4 0.00% 0.00% 0.00% 0 IPC Event Notifi
35 58525 9554088 6 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
36 0 1 0 0.00% 0.00% 0.00% 0 Platform appsess
37 955 163104 5 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
38 9541 1957160 4 0.00% 0.00% 0.00% 0 IPC Service NonC
39 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
40 71852 9554096 7 0.00% 0.00% 0.00% 0 IPC Periodic Tim
25 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
27 339 11043 30 0.00% 0.00% 0.00% 0 DB Lock Manager
43 102098 2451596 41 0.00% 0.00% 0.00% 0 IPC Seat Manager
44 3371 559205 6 0.00% 0.00% 0.00% 0 IPC Check Queue
45 25 224 111 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
8 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
47 37475 978622 38 0.00% 0.00% 0.00% 0 IPC Keep Alive M
48 96726 1957160 49 0.00% 0.00% 0.00% 0 IPC Loadometer
49 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Deta
50 0 1 0 0.00% 0.00% 0.00% 0 SENSOR-MGR event
51 5851 978622 5 0.00% 0.00% 0.00% 0 Compute SRP rate
30 0 2 0 0.00% 0.00% 0.00% 0 ATM AutoVC Perio
41 51855 9554088 5 0.00% 0.00% 0.00% 0 IPC Deferred Por
54 4 11 363 0.00% 0.00% 0.00% 0 License IPC stat
55 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv
56 14800 1140708 12 0.00% 0.00% 0.00% 0 Net Input
57 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
58 0 1 0 0.00% 0.00% 0.00% 0 IOSXE signals IO
59 0 2 0 0.00% 0.00% 0.00% 0 SMART
60 5 11 454 0.00% 0.00% 0.00% 0 client_entity_se
61 0 1 0 0.00% 0.00% 0.00% 0 RF SCTPthread
62 0 1 0 0.00% 0.00% 0.00% 0 CHKPT RG SCTPthr
63 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
64 1372 8022 171 0.00% 0.00% 0.00% 0 crypto sw pk pro
65 0 1 0 0.00% 0.00% 0.00% 0 License Client N
66 1546 5798 266 0.00% 0.00% 0.00% 0 SAEventLog
67 34 52 653 0.00% 0.00% 0.00% 0 SAStorage
68 0 4 0 0.00% 0.00% 0.00% 0 SASConnect
69 61452 5157896 11 0.00% 0.00% 0.00% 0 SASRcvWQ
70 1 5 200 0.00% 0.00% 0.00% 0 SACConnect
71 56178 5168772 10 0.00% 0.00% 0.00% 0 SACRcvWQ
72 0 1 0 0.00% 0.00% 0.00% 0 Image License br
73 12636 326206 38 0.00% 0.00% 0.00% 0 Licensing Auto U
74 23 3 7666 0.00% 0.00% 0.00% 0 License HA Consi
42 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
76 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
46 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
78 0 5 0 0.00% 0.00% 0.00% 0 IDB Work
79 1946 114263 17 0.00% 0.00% 0.00% 0 Logger
80 108282 9782898 11 0.00% 0.00% 0.00% 0 TTY Background
81 790 367 2152 0.00% 0.00% 0.00% 0 EWLC IOSD CAPWAP
82 0 2 0 0.00% 0.00% 0.00% 0 EWLC IOSD HAINFR
83 550913 9795854 56 0.00% 0.00% 0.00% 0 GATEWAY monitor
84 36 27 1333 0.00% 0.00% 0.00% 0 CTS CORE
52 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
86 71528 4893507 14 0.00% 0.00% 0.00% 0 SASRcvWQWrk1
87 20 1064 18 0.00% 0.00% 0.00% 0 HA SSO GARP Proc
88 0 4 0 0.00% 0.00% 0.00% 0 mDNS HA
89 0 5 0 0.00% 0.00% 0.00% 0 mDNS HA CF
90 3 10 300 0.00% 0.00% 0.00% 0 CTS HA
91 0 5 0 0.00% 0.00% 0.00% 0 CTS HA IPC flow
92 0 1 0 0.00% 0.00% 0.00% 0 CTS HA operation
6 0 225 0 0.00% 0.00% 0.00% 0 Retransmission o
94 146803 5947939 24 0.00% 0.00% 0.00% 0 IOSD chasfs task
95 0 7 0 0.00% 0.00% 0.00% 0 Crimson interfac
96 870374 97861 8893 0.00% 0.00% 0.00% 0 Crimson Database
97 4328 11217 385 0.00% 0.00% 0.00% 0 Crimson flush tr
53 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
99 13384 1398029 9 0.00% 0.00% 0.00% 0 REDUNDANCY FSM
75 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon
101 0 1 0 0.00% 0.00% 0.00% 0 Punt FP Stats Du
102 415866 4892346 85 0.00% 0.00% 0.00% 0 PuntInject Keepa
103 0 8 0 0.00% 0.00% 0.00% 0 IF-MGR control p
104 1 14 71 0.00% 0.00% 0.00% 0 IF-MGR event pro
105 1 3 333 0.00% 0.00% 0.00% 0 CMAN RP Msg Proc
106 80273 9782942 8 0.00% 0.00% 0.00% 0 Environmental Mo
107 65339 9782915 6 0.00% 0.00% 0.00% 0 RP HA Periodic
108 226678 486052 466 0.00% 0.00% 0.00% 0 DBAL EVENTS
109 0 3 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
110 288 4680 61 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
111 147399 3733143 39 0.00% 0.00% 0.00% 0 cpf_process_tpQ
112 2 9 222 0.00% 0.00% 0.00% 0 STACK MGR Proces
113 0 3 0 0.00% 0.00% 0.00% 0 Network-rf Notif
114 0 1 0 0.00% 0.00% 0.00% 0 CONSOLE helper p
115 1 7 142 0.00% 0.00% 0.00% 0 IOSXE-RP NGIO HA
116 0 5 0 0.00% 0.00% 0.00% 0 CEF RRP RF waite
117 0 5 0 0.00% 0.00% 0.00% 0 CWAN APS HA Proc
118 538216 16202942 33 0.00% 0.00% 0.00% 0 REDUNDANCY peer
119 701505 97861846 7 0.00% 0.00% 0.00% 0 100ms check
120 1660 163114 10 0.00% 0.00% 0.00% 0 RF CWAN HA Proce
121 1 13 76 0.00% 0.00% 0.00% 0 CWAN IF EVENT HA
122 1 6 166 0.00% 0.00% 0.00% 0 ANCP HA
123 0 5 0 0.00% 0.00% 0.00% 0 ANCP HA IPC flow
124 0 1 0 0.00% 0.00% 0.00% 0 QoS HA ID RETAIN
125 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
126 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
127 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
128 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
129 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
130 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
131 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
132 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
133 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
134 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
135 0 1 0 0.00% 0.00% 0.00% 0 CHKPT Test clien
136 1 14 71 0.00% 0.00% 0.00% 0 DHCPC HA
137 0 12 0 0.00% 0.00% 0.00% 0 DHCPD HA
138 2 15 133 0.00% 0.00% 0.00% 0 DHCPv6 Relay HA
139 1 13 76 0.00% 0.00% 0.00% 0 DHCPv6 Server HA
140 0 13 0 0.00% 0.00% 0.00% 0 IPV6_ND HA
141 0 4 0 0.00% 0.00% 0.00% 0 SISF HA Process
142 99118 1856840 53 0.00% 0.00% 0.00% 0 ARP HA
143 0 1 0 0.00% 0.00% 0.00% 0 XDR RRP RF waite
77 100465 6077931 16 0.00% 0.00% 0.00% 0 Net Background
145 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Punt IP
146 0 1 0 0.00% 0.00% 0.00% 0 ACL Log Punt Ser
147 0 1 0 0.00% 0.00% 0.00% 0 ACL deny punt se
85 75 2196 34 0.00% 0.00% 0.00% 0 SXP CORE
149 0 1 0 0.00% 0.00% 0.00% 0 OFSDN Punject Pr
150 3391609 602447086 5 0.00% 0.03% 0.02% 0 SIS Punt Process
151 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP SPA TSM
152 0 5 0 0.00% 0.00% 0.00% 0 IOSXE-RP QFP HA
153 0 5 0 0.00% 0.00% 0.00% 0 IKE HA Mgr
154 0 5 0 0.00% 0.00% 0.00% 0 IPSEC HA Mgr
155 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-HA
156 26573 2446516 10 0.00% 0.00% 0.00% 0 RF Master Main T
157 207874 2446341 84 0.00% 0.00% 0.00% 0 RF Master Status
158 79804 4892369 16 0.00% 0.00% 0.00% 0 SACRcvWQWrk1
159 63867 4892374 13 0.00% 0.00% 0.00% 0 SACRcvWQWrk2
160 1 385 2 0.00% 0.00% 0.00% 0 BACK CHECK
161 560981 811479 691 0.00% 0.00% 0.00% 0 SAMsgThread
162 593508 978622 606 0.00% 0.00% 0.00% 0 Compute load avg
163 1710076 650222 2629 0.00% 0.01% 0.00% 0 Per-minute Jobs
7 2 4 500 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
165 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
166 27 2160 12 0.00% 0.00% 0.00% 0 Transport Port A
167 14 25 560 0.00% 0.00% 0.00% 0 ACT2 Crypto Engi
168 0 2 0 0.00% 0.00% 0.00% 0 FEC_Link_event_h
169 0 1 0 0.00% 0.00% 0.00% 0 NGWC L2M
170 1 4 250 0.00% 0.00% 0.00% 0 EEM ED MAT
171 16071 1080908 14 0.00% 0.00% 0.00% 0 EEM ED ND
172 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP FastPat
173 0 1 0 0.00% 0.00% 0.00% 0 Src Fltr backgro
174 54567 9554085 5 0.00% 0.00% 0.00% 0 fanrp_macsec
175 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST rest
176 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST hand
177 0 1 0 0.00% 0.00% 0.00% 0 MACSEC POST hand
178 0 1 0 0.00% 0.00% 0.00% 0 DSX3MIB ll handl
179 54629 9554084 5 0.00% 0.00% 0.00% 0 fanrp_l2fib
180 0 1 0 0.00% 0.00% 0.00% 0 POS APS Event Pr
181 0 2 0 0.00% 0.00% 0.00% 0 Netsync ESMC pro
182 5 3 1666 0.00% 0.00% 0.00% 0 netclk_process
183 0 6 0 0.00% 0.00% 0.00% 0 netclk_ha_proces
184 0 1 0 0.00% 0.00% 0.00% 0 SSLVPN Register
185 0 1 0 0.00% 0.00% 0.00% 0 IPSec background
186 0 4 0 0.00% 0.00% 0.00% 0 FPD Management P
187 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
188 0 1 0 0.00% 0.00% 0.00% 0 BFD HW EVENT
98 1510913 39072022 38 0.00% 0.01% 0.00% 0 Crimson config p
100 0 17 0 0.00% 0.00% 0.00% 0 SBC IPC Hold Que
191 0 2 0 0.00% 0.00% 0.00% 0 BMA Background
192 0 2 0 0.00% 0.00% 0.00% 0 VMI Background
193 0 1 0 0.00% 0.00% 0.00% 0 WSMA_NOTIFY
189 0 1 0 0.00% 0.00% 0.00% 0 BFD IPV6 ADDR CH
195 0 1 0 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
196 0 2 0 0.00% 0.00% 0.00% 0 Inter Chassis Pr
197 48961 9782912 5 0.00% 0.00% 0.00% 0 CWAN CHOCX PROCE
198 0 1 0 0.00% 0.00% 0.00% 0 CE3 Mailbox
199 0 1 0 0.00% 0.00% 0.00% 0 CT3 Mailbox
200 0 1 0 0.00% 0.00% 0.00% 0 HAL Mailbox
201 0 2 0 0.00% 0.00% 0.00% 0 MIP Mailbox
202 2162 170778 12 0.00% 0.00% 0.00% 0 CWAN OIR Handler
203 29723 3261818 9 0.00% 0.00% 0.00% 0 ACE event
204 96 2739 35 0.00% 0.00% 0.00% 0 ACE HAPI
205 617 81552 7 0.00% 0.00% 0.00% 0 ACE policy loade
206 0 1 0 0.00% 0.00% 0.00% 0 TP CUTOVER EVENT
207 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP FastPat
208 0 1 0 0.00% 0.00% 0.00% 0 ASR1K ESMC Proce
209 0 1 0 0.00% 0.00% 0.00% 0 ASR1000-RP SPA A
210 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
211 53966 9782902 5 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
212 28092 641698 43 0.00% 0.00% 0.00% 0 DTP Protocol
213 653 637 1025 0.00% 0.00% 0.00% 0 PKI/SSL IPC proc
214 0 2 0 0.00% 0.00% 0.00% 0 PKI_SSL LSC Enro
215 4 7 571 0.00% 0.00% 0.00% 0 PKI_SSL Trustpoi
216 191 19 10052 0.00% 0.00% 0.00% 0 PKI/SSL WLC IPC
217 0 2 0 0.00% 0.00% 0.00% 0 SKA IPC process
218 6748 978608 6 0.00% 0.00% 0.00% 0 Ethchnl
219 3 374 8 0.00% 0.00% 0.00% 0 802.1x switch
220 584 132 4424 0.00% 0.00% 0.00% 0 SNMP MA SA
221 155 10948 14 0.00% 0.00% 0.00% 0 AAA Server
222 144 7327 19 0.00% 0.00% 0.00% 0 AAA ACCT Proc
223 1 1 1000 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
224 269901 2345014 115 0.00% 0.00% 0.00% 0 CDP Protocol
225 20087 55859 359 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
226 2871 163106 17 0.00% 0.00% 0.00% 0 Call Home Timer
227 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
228 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
229 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
230 138791 9782912 14 0.00% 0.00% 0.00% 0 FHRP Main thread
231 0 1 0 0.00% 0.00% 0.00% 0 TRACK Main threa
232 0 1 0 0.00% 0.00% 0.00% 0 TRACK Client thr
233 0 1 0 0.00% 0.00% 0.00% 0 VRRP Main thread
234 1553775 152749436 10 0.00% 0.01% 0.00% 0 VRRS Main thread
235 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
236 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
237 0 2 0 0.00% 0.00% 0.00% 0 HQF BLT UPDATE
238 0 1 0 0.00% 0.00% 0.00% 0 HQF TARGET DYNAM
239 35611 1096399 32 0.00% 0.00% 0.00% 0 IP ARP Adjacency
240 1775834 302886831 5 0.00% 0.00% 0.00% 0 IP ARP Retry Age
241 63417 1043483 60 0.00% 0.00% 0.00% 0 IP Input
242 0 33 0 0.00% 0.00% 0.00% 0 ICMP event handl
243 0 1 0 0.00% 0.00% 0.00% 0 FQDN ACL Mgr
244 92635 9782942 9 0.00% 0.00% 0.00% 0 mDNS
245 0 3 0 0.00% 0.00% 0.00% 0 PIM register asy
246 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
247 1590535 1631384 974 0.00% 0.00% 0.00% 0 SNMP LA Cache In
248 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
249 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
250 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
251 0 1 0 0.00% 0.00% 0.00% 0 PKI Trustpool
252 0 6 0 0.00% 0.00% 0.00% 0 RIB LM VALIDATE
253 4 400 10 0.00% 0.00% 0.00% 0 SSM connection m
254 925 163104 5 0.00% 0.00% 0.00% 0 SSS Manager
255 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
256 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
257 283500 38227364 7 0.00% 0.00% 0.00% 0 SSS Feature Time
258 0 2 0 0.00% 0.00% 0.00% 0 Spanning Tree
259 0 2 0 0.00% 0.00% 0.00% 0 SpanTree Msg
260 487335 76288091 6 0.00% 0.00% 0.00% 0 Tunnel BGP
261 0 1 0 0.00% 0.00% 0.00% 0 VRRS
262 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
263 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Sub-
264 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA
265 0 2 0 0.00% 0.00% 0.00% 0 Maintenance mode
266 0 2 0 0.00% 0.00% 0.00% 0 Ethernet LMI
267 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
268 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM
269 1 9 111 0.00% 0.00% 0.00% 0 EPM IAL Process
270 0 2 0 0.00% 0.00% 0.00% 0 SNMP DBAL WRAPPE
271 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
272 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
273 102079 415874 245 0.00% 0.00% 0.00% 0 mcp callhome per
274 0 1 0 0.00% 0.00% 0.00% 0 PPCP RP Stats Ba
275 1 2 500 0.00% 0.00% 0.00% 0 MKA
276 215 32621 6 0.00% 0.00% 0.00% 0 Appnav auto disc
277 0 1 0 0.00% 0.00% 0.00% 0 L2FIB Timer Disp
278 0 1 0 0.00% 0.00% 0.00% 0 MLRIB L2 Msg Thr
279 0 2 0 0.00% 0.00% 0.00% 0 NVE main thread
280 987 163105 6 0.00% 0.00% 0.00% 0 Spanning Tree St
281 1 5 200 0.00% 0.00% 0.00% 0 RABAPOL HA
282 0 6 0 0.00% 0.00% 0.00% 0 RABAPOL HA IPC f
283 58 311 186 0.00% 0.00% 0.00% 0 TEMPLATE HA
284 0 6 0 0.00% 0.00% 0.00% 0 DVLAN HA
285 32 297 107 0.00% 0.00% 0.00% 0 CCM
286 0 5 0 0.00% 0.00% 0.00% 0 CCM IPC flow con
287 0 2 0 0.00% 0.00% 0.00% 0 RG Faults Timer
288 0 1 0 0.00% 0.00% 0.00% 0 RG VP
289 0 2 0 0.00% 0.00% 0.00% 0 RG AR
290 0 2 0 0.00% 0.00% 0.00% 0 RG Protocol Time
291 0 2 0 0.00% 0.00% 0.00% 0 RG Transport Tim
292 1 3 333 0.00% 0.00% 0.00% 0 HDLC HA
293 1 1 1000 0.00% 0.00% 0.00% 0 SBC initializer
294 0 5 0 0.00% 0.00% 0.00% 0 SVM HA
295 1092775 97861952 11 0.00% 0.00% 0.00% 0 UDLD
296 113763 9556502 11 0.00% 0.00% 0.00% 0 L2RIB Thread
297 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
298 0 2 0 0.00% 0.00% 0.00% 0 DAPR ER process
299 0 1 0 0.00% 0.00% 0.00% 0 IEDGE ACCT TIMER
300 0 1 0 0.00% 0.00% 0.00% 0 ISG CMD HANDLER
301 0 1 0 0.00% 0.00% 0.00% 0 IMA PROC
302 13863 2389216 5 0.00% 0.00% 0.00% 0 IP Lite session
303 0 2 0 0.00% 0.00% 0.00% 0 IP PORTBUNDLE
304 0 2 0 0.00% 0.00% 0.00% 0 SSS Mobility mes
305 9937 2389210 4 0.00% 0.00% 0.00% 0 IP Static Sessio
306 0 2 0 0.00% 0.00% 0.00% 0 DVLAN Config Pro
307 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
308 1970908 302887357 6 0.00% 0.01% 0.00% 0 IPAM Manager
309 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
310 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
311 0 1 0 0.00% 0.00% 0.00% 0 O-UNI Client Msg
312 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
313 0 5 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
314 0 1 0 0.00% 0.00% 0.00% 0 st_pw_oam
315 0 1 0 0.00% 0.00% 0.00% 0 SR SID Mgr
316 0 1 0 0.00% 0.00% 0.00% 0 AAA EPD HANDLER
317 0 1 0 0.00% 0.00% 0.00% 0 PM EPD API
318 0 1 0 0.00% 0.00% 0.00% 0 DM Proc
319 0 1 0 0.00% 0.00% 0.00% 0 RADIUS Proxy
320 0 1 0 0.00% 0.00% 0.00% 0 SSS PM SHIM QOS
321 0 1 0 0.00% 0.00% 0.00% 0 LONG TO SHORT NA
322 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
323 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
324 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
325 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
326 0 2 0 0.00% 0.00% 0.00% 0 radius radsec cl
327 2111 69688 30 0.00% 0.00% 0.00% 0 TCP Timer
328 2727 19522 139 0.00% 0.00% 0.00% 0 TCP Protocols
329 138 19494 7 0.00% 0.00% 0.00% 0 Socket Timers
330 233184 97480 2392 0.00% 0.00% 0.00% 0 HTTP CORE
331 0 2 0 0.00% 0.00% 0.00% 0 XDR background p
332 15181 326614 46 0.00% 0.00% 0.00% 0 XDR mcast
333 0 5 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
334 98707 965206 102 0.00% 0.00% 0.00% 0 XDR receive
335 1 7 142 0.00% 0.00% 0.00% 0 IPC LC Message H
336 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
337 841 163104 5 0.00% 0.00% 0.00% 0 FRR Background P
338 16994 1088116 15 0.00% 0.00% 0.00% 0 CEF background p
339 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
340 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
341 0 4 0 0.00% 0.00% 0.00% 0 LSD HA Proc
342 3 164 18 0.00% 0.00% 0.00% 0 CEF RP Backgroun
343 506105 9782906 51 0.00% 0.00% 0.00% 0 nbar-graph-sende
344 22785 1957158 11 0.00% 0.00% 0.00% 0 nbar-custom-prot
345 117620 9782902 12 0.00% 0.00% 0.00% 0 nbar-sdavc-sched
346 2275 163104 13 0.00% 0.00% 0.00% 0 nbar-pp-monitor
347 0 1 0 0.00% 0.00% 0.00% 0 Tunnel FIB
348 0 1 0 0.00% 0.00% 0.00% 0 RETRY_REPOPULATE
349 4 555 7 0.00% 0.00% 0.00% 0 Flow Exporter Ti
350 1 2 500 0.00% 0.00% 0.00% 0 Flow Exporter Pa
351 0 15 0 0.00% 0.00% 0.00% 0 NEXTHOP_MAC_PROC
352 0 2 0 0.00% 0.00% 0.00% 0 Ewlc copy mqipc
353 0 2 0 0.00% 0.00% 0.00% 0 Ewlc cli mqipc h
354 0 1 0 0.00% 0.00% 0.00% 0 AP upgrade IPC p
355 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
356 8 4 2000 0.00% 0.00% 0.00% 0 Wireless Arp Pro
357 23 385 59 0.00% 0.00% 0.00% 0 IGMPSN L2MCM
358 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD
359 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN
360 0 2 0 0.00% 0.00% 0.00% 0 EFP Errd
361 0 2 0 0.00% 0.00% 0.00% 0 Ether EFP Proces
362 13 384 33 0.00% 0.00% 0.00% 0 MLDSN L2MCM
363 0 1 0 0.00% 0.00% 0.00% 0 MRD
364 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP
365 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR
366 0 4 0 0.00% 0.00% 0.00% 0 L2MCAST Wireless
367 0 9 0 0.00% 0.00% 0.00% 0 IGMPSN-HA
368 0 2 0 0.00% 0.00% 0.00% 0 igmpsn capwap id
5 0 1 0 0.00% 0.00% 0.00% 0 CTS SGACL db cor
370 0 9 0 0.00% 0.00% 0.00% 0 L2MCAST-HA-WIREL
371 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
194 1595716 1956806 815 0.00% 0.00% 0.00% 0 MGMTE stats Proc
373 0 3 0 0.00% 0.00% 0.00% 0 AC Mgr
374 0 5 0 0.00% 0.00% 0.00% 0 EVPN VPWS Thread
375 0 2 0 0.00% 0.00% 0.00% 0 Tunnel
376 0 2 0 0.00% 0.00% 0.00% 0 ATIP_UDP_TSK
377 160518 5650230 28 0.00% 0.00% 0.00% 0 SNMP Timers
4 186 741 251 0.00% 0.00% 0.00% 0 RF Slave Main Th
379 14 17 823 0.00% 0.00% 0.00% 0 IP RIB Update
380 1454 163484 8 0.00% 0.00% 0.00% 0 IP Background
381 13 411 31 0.00% 0.00% 0.00% 0 IP Connected Rou
372 1 2 500 0.00% 0.00% 0.00% 0 VPWS Thread
383 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Res
384 46878 4892364 9 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
385 0 5 0 0.00% 0.00% 0.00% 0 ADJ background
386 0 11 0 0.00% 0.00% 0.00% 0 Collection proce
387 1 6 166 0.00% 0.00% 0.00% 0 ADJ resolve proc
388 0 1 0 0.00% 0.00% 0.00% 0 COPS
389 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder
390 0 3 0 0.00% 0.00% 0.00% 0 Service Routing
391 8 737 10 0.00% 0.00% 0.00% 0 SR CapMan Proces
392 11 881 12 0.00% 0.00% 0.00% 0 DNS Service
3 58 73 794 0.00% 0.00% 0.00% 0 OVLD SPA Backgro
394 315 32090 9 0.00% 0.00% 0.00% 0 MFIB Master back
395 0 2 0 0.00% 0.00% 0.00% 0 NAT-ROUTE
396 39 378 103 0.00% 0.00% 0.00% 0 MVPN Mgr Process
397 1 2 500 0.00% 0.00% 0.00% 0 Multicast Offloa
398 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
399 1 17 58 0.00% 0.00% 0.00% 0 static
400 0 2 0 0.00% 0.00% 0.00% 0 App Route Proces
401 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Cleanup
402 0 3 0 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
403 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Static Hand
404 0 2 0 0.00% 0.00% 0.00% 0 DHCPv6 LQ client
405 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
406 0 1 0 0.00% 0.00% 0.00% 0 LAPB Process
407 1 2 500 0.00% 0.00% 0.00% 0 PPP NBF
408 59383 9782909 6 0.00% 0.00% 0.00% 0 PfR BR Learn
409 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
410 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
411 18124 978607 18 0.00% 0.00% 0.00% 0 QoS stats proces
412 0 2 0 0.00% 0.00% 0.00% 0 RBSCP Background
413 0 2 0 0.00% 0.00% 0.00% 0 SCTP Main Proces
414 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
415 0 5 0 0.00% 0.00% 0.00% 0 XC RIB MGR
416 0 1 0 0.00% 0.00% 0.00% 0 SSL background p
417 0 1 0 0.00% 0.00% 0.00% 0 Select Timers
418 0 2 0 0.00% 0.00% 0.00% 0 HTTP Process
419 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
420 10 444 22 0.00% 0.00% 0.00% 0 BSO_Query
421 35 29 1206 0.00% 0.00% 0.00% 0 Ether-SPA backgr
422 0 2 0 0.00% 0.00% 0.00% 0 Ether Infra RP
423 0 5 0 0.00% 0.00% 0.00% 0 CFM HA IPC messa
424 0 1 0 0.00% 0.00% 0.00% 0 Ethernet PM Proc
425 0 2 0 0.00% 0.00% 0.00% 0 Ethernet PM Soft
426 24719 2935115 8 0.00% 0.00% 0.00% 0 Ethernet PM Moni
427 0 1 0 0.00% 0.00% 0.00% 0 Ethernet Datapla
428 0 5 0 0.00% 0.00% 0.00% 0 ELB HA IPC flow
429 0 1 0 0.00% 0.00% 0.00% 0 TCP HA PROC
430 0 6 0 0.00% 0.00% 0.00% 0 BGP HA SSO
431 1 9 111 0.00% 0.00% 0.00% 0 RSVP SYNC
432 17 2721 6 0.00% 0.00% 0.00% 0 SSH Event handle
433 1 8 125 0.00% 0.00% 0.00% 0 XDR FOF process
434 1 178 5 0.00% 0.00% 0.00% 0 SR Policy Mgr
435 0 6 0 0.00% 0.00% 0.00% 0 SR Policy HA
436 0 1 0 0.00% 0.00% 0.00% 0 PM HA Bulk Sync
437 0 2 0 0.00% 0.00% 0.00% 0 BD Route Msg Hol
438 0 1 0 0.00% 0.00% 0.00% 0 BD Route Rx Proc
439 1 4 250 0.00% 0.00% 0.00% 0 BD MACSEC HA
440 0 2 0 0.00% 0.00% 0.00% 0 BD MACSEC HA CHK
441 0 5 0 0.00% 0.00% 0.00% 0 BD MACSEC Bulk S
442 0 2 0 0.00% 0.00% 0.00% 0 L2FIB Event Disp
443 0 1 0 0.00% 0.00% 0.00% 0 EVPN main thread
444 0 1 0 0.00% 0.00% 0.00% 0 NVE MGR RWATCH T
445 0 2 0 0.00% 0.00% 0.00% 0 vxlan sr main
446 0 5 0 0.00% 0.00% 0.00% 0 STP HA IPC flow
447 0 7 0 0.00% 0.00% 0.00% 0 AAA HA
448 0 1 0 0.00% 0.00% 0.00% 0 AAA HA cleanup
449 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve
450 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_mraps_hsp
451 1 5 200 0.00% 0.00% 0.00% 0 AC HA Bulk Sync
452 0 4 0 0.00% 0.00% 0.00% 0 ATM HA
453 0 5 0 0.00% 0.00% 0.00% 0 ATM HA IPC flow
454 0 1 0 0.00% 0.00% 0.00% 0 ATM HA AC
455 0 5 0 0.00% 0.00% 0.00% 0 BFD HA
456 0 4 0 0.00% 0.00% 0.00% 0 FR HA
457 1 4 250 0.00% 0.00% 0.00% 0 GLBP HA
458 0 4 0 0.00% 0.00% 0.00% 0 HSRP HA
459 25177 2389210 10 0.00% 0.00% 0.00% 0 IP SIP Process
460 1 13 76 0.00% 0.00% 0.00% 0 MRIB RP PROCESS
461 0 2 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy
462 1 3 333 0.00% 0.00% 0.00% 0 IPv6 ACL RP Proc
463 0 5 0 0.00% 0.00% 0.00% 0 Netsync IPC flow
464 0 2 0 0.00% 0.00% 0.00% 0 PPPoE VRRS EVT M
465 0 1 0 0.00% 0.00% 0.00% 0 RG If-Mgr Timer
466 1 2 500 0.00% 0.00% 0.00% 0 RG Media Timer
467 9 4 2250 0.00% 0.00% 0.00% 0 MCPRP RG Timer
468 0 3 0 0.00% 0.00% 0.00% 0 VFI HA Bulk Sync
469 0 5 0 0.00% 0.00% 0.00% 0 XC RIB HA Bulk S
470 0 5 0 0.00% 0.00% 0.00% 0 XC BGP SIG RIB H
471 0 5 0 0.00% 0.00% 0.00% 0 EVPN HA Bulk Syn
472 0 1 0 0.00% 0.00% 0.00% 0 VPDN CCM Backgro
473 0 4 0 0.00% 0.00% 0.00% 0 VRRP HA
474 0 5 0 0.00% 0.00% 0.00% 0 VTEMPLATE IPC fl
475 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Punt Qo
476 1 118 8 0.00% 0.00% 0.00% 0 CEM PROC
477 0 4 0 0.00% 0.00% 0.00% 0 CEM HA
478 0 1 0 0.00% 0.00% 0.00% 0 CEM HA AC
479 0 2 0 0.00% 0.00% 0.00% 0 L2X Switching Ev
480 142620 19102627 7 0.00% 0.00% 0.00% 0 TLSCLIENT_PROCES
481 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
482 0 2 0 0.00% 0.00% 0.00% 0 IP Inband Sessio
483 0 1 0 0.00% 0.00% 0.00% 0 DHCP SIP
484 17474 2446379 7 0.00% 0.00% 0.00% 0 FRR Manager
485 0 2 0 0.00% 0.00% 0.00% 0 MFI Comm RP Proc
486 0 2 0 0.00% 0.00% 0.00% 0 Path set broker
487 0 2 0 0.00% 0.00% 0.00% 0 LFD Label Block
488 2 41 48 0.00% 0.00% 0.00% 0 LDP HA
489 0 4 0 0.00% 0.00% 0.00% 0 MPLS VPN HA Clie
490 1 13 76 0.00% 0.00% 0.00% 0 TSPTUN HA
491 1 4 250 0.00% 0.00% 0.00% 0 RSVP HA Services
492 0 2 0 0.00% 0.00% 0.00% 0 TE NSR OOS DB Pr
493 0 6 0 0.00% 0.00% 0.00% 0 MPLS TP HA
494 0 1 0 0.00% 0.00% 0.00% 0 AToM HA Bulk Syn
495 0 4 0 0.00% 0.00% 0.00% 0 AToM MGR HA IPC
496 0 2 0 0.00% 0.00% 0.00% 0 OAM DPM
497 0 2 0 0.00% 0.00% 0.00% 0 OAM DPM BG TASK
498 0 2 0 0.00% 0.00% 0.00% 0 LFDp Input Proc
499 0 1 0 0.00% 0.00% 0.00% 0 HA-IDB-SYNC
500 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
501 0 2 0 0.00% 0.00% 0.00% 0 Diameter Base pr
502 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
503 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
504 81727 9782949 8 0.00% 0.00% 0.00% 0 FQDN Mgr Main
505 0 1 0 0.00% 0.00% 0.00% 0 FQDN Mgr Packet
506 0 3 0 0.00% 0.00% 0.00% 0 LDAP process
507 0 1 0 0.00% 0.00% 0.00% 0 Opaque Database
508 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
509 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
510 52 4596 11 0.00% 0.00% 0.00% 0 LOCAL AAA
511 0 2 0 0.00% 0.00% 0.00% 0 DiagCard1/-1
512 6520 85051 76 0.00% 0.00% 0.00% 0 TPLUS
513 1 4 250 0.00% 0.00% 0.00% 0 Crypto WUI
514 0 3 0 0.00% 0.00% 0.00% 0 EST Client
515 0 1 0 0.00% 0.00% 0.00% 0 DynCmd Package P
516 0 1 0 0.00% 0.00% 0.00% 0 Consent token pr
517 1550189 152749351 10 0.00% 0.00% 0.00% 0 MMA DB TIMER
518 1 2 500 0.00% 0.00% 0.00% 0 FLEX DSPRM MAIN
519 0 2 0 0.00% 0.00% 0.00% 0 VSP_MGR
520 0 2 0 0.00% 0.00% 0.00% 0 STUN_APP
521 0 1 0 0.00% 0.00% 0.00% 0 STUN_TEST
522 0 2 0 0.00% 0.00% 0.00% 0 Manet Infra Back
523 0 1 0 0.00% 0.00% 0.00% 0 EAP Process
524 124452 19102627 6 0.00% 0.00% 0.00% 0 Timer Library
525 0 2 0 0.00% 0.00% 0.00% 0 Crypto Support
526 0 1 0 0.00% 0.00% 0.00% 0 IPSECv6 PS Proc
527 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
528 3 183 16 0.00% 0.00% 0.00% 0 MPLS Auto Mesh P
529 1349 5436 248 0.00% 0.00% 0.00% 0 NIST rng proc
530 1 1 1000 0.00% 0.00% 0.00% 0 AAA Proxy
531 0 1 0 0.00% 0.00% 0.00% 0 EWLC/AAA IPC pro
532 0 1 0 0.00% 0.00% 0.00% 0 EWLC/AAA IPC pro
533 0 1 0 0.00% 0.00% 0.00% 0 NGINX/AAA IPC pr
534 0 5 0 0.00% 0.00% 0.00% 0 crypto engine pr
535 191478 9786196 19 0.00% 0.00% 0.00% 0 RSCMSM VOLUME MO
536 0 2 0 0.00% 0.00% 0.00% 0 CCSIP_EVENT_TRAC
537 0 2 0 0.00% 0.00% 0.00% 0 Sip MPA
538 1 1 1000 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
539 0 1 0 0.00% 0.00% 0.00% 0 iosp_eem_global_
540 0 1 0 0.00% 0.00% 0.00% 0 IP TRUST Registe
541 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA
542 4 115 34 0.00% 0.00% 0.00% 0 RSA background p
543 242 16819 14 0.00% 0.00% 0.00% 0 Crypto CA
544 0 3 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
545 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-Rev-P
546 0 1 0 0.00% 0.00% 0.00% 0 PKI OCSP
547 0 1 0 0.00% 0.00% 0.00% 0 PKI Revocation
548 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
549 0 2 0 0.00% 0.00% 0.00% 0 File Copy Handle
550 0 5 0 0.00% 0.00% 0.00% 0 COND_DEBUG HA IP
551 0 15 0 0.00% 0.00% 0.00% 0 PIM HA
552 0 2 0 0.00% 0.00% 0.00% 0 MMON PROCESS
553 0 1 0 0.00% 0.00% 0.00% 0 QOS PERUSER
554 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN
555 0 1 0 0.00% 0.00% 0.00% 0 http client proc
556 2626 163103 16 0.00% 0.00% 0.00% 0 RADIUS IO STATS
557 13 5 2600 0.00% 0.00% 0.00% 0 TPS IPC Process
558 156924 10110694 15 0.00% 0.00% 0.00% 0 Crypto IKEv2
559 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 AAA handle
560 0 3 0 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE
561 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT
562 0 4 0 0.00% 0.00% 0.00% 0 Crypto IKE Dispa
563 3 81 37 0.00% 0.00% 0.00% 0 Crypto IKMP
564 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
565 4770 489309 9 0.00% 0.00% 0.00% 0 IPSEC key engine
566 0 1 0 0.00% 0.00% 0.00% 0 Crypto ACL
567 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc
568 0 2 0 0.00% 0.00% 0.00% 0 GKM GM Process
569 0 1 0 0.00% 0.00% 0.00% 0 GKM KS PROCESS
570 0 2 0 0.00% 0.00% 0.00% 0 SEGMENT ROUTING
571 0 2 0 0.00% 0.00% 0.00% 0 SRMS_PROCESS
572 0 1 0 0.00% 0.00% 0.00% 0 LS LIB
573 0 2 0 0.00% 0.00% 0.00% 0 Lawful Intercept
574 0 2 0 0.00% 0.00% 0.00% 0 LI messaging
575 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr
576 5 383 13 0.00% 0.00% 0.00% 0 VTP Trap Process
577 807 16139 50 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
578 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client
579 0 1 0 0.00% 0.00% 0.00% 0 dcm_cli_engine
580 0 3 0 0.00% 0.00% 0.00% 0 dcm_cli_provider
581 0 4 0 0.00% 0.00% 0.00% 0 DCM Core Thread
582 255 58352 4 0.00% 0.00% 0.00% 0 EEM ED Syslog
583 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Generic
584 0 4 0 0.00% 0.00% 0.00% 0 EEM ED NHRP
585 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Track
586 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Routing
587 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Resource
588 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
589 0 2 0 0.00% 0.00% 0.00% 0 DiagCard2/-1
590 36905 974729 37 0.00% 0.00% 0.00% 0 Flash low disk s
591 0 1 0 0.00% 0.00% 0.00% 0 Policy HA Timer
592 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Access Cont
593 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM
594 52857 489159 108 0.00% 0.00% 0.00% 0 SPA ENTITY Proce
595 0 2 0 0.00% 0.00% 0.00% 0 DAPR RM PROCESS
596 0 2 0 0.00% 0.00% 0.00% 0 DAPR RM RCV PROC
597 0 1 0 0.00% 0.00% 0.00% 0 DAPR FNF Collect
598 0 2 0 0.00% 0.00% 0.00% 0 MCPRP UIDP Proce
599 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 FlexVPN Pr
600 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 Cluster Lo
601 0 1 0 0.00% 0.00% 0.00% 0 SONET Traps
602 0 2 0 0.00% 0.00% 0.00% 0 ISG MIB jobs Man
603 0 3 0 0.00% 0.00% 0.00% 0 VTEMPLATE Backgr
604 3882 32533 119 0.00% 0.00% 0.00% 0 SLE DB Util
605 0 30 0 0.00% 0.00% 0.00% 0 EWLC QOS MSG PRO
606 31 11 2818 0.00% 0.00% 0.00% 0 FNF_EWLC_WIRELES
607 36316 3423 10609 0.00% 0.00% 0.00% 0 EWLC License ODM
608 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs ICMP Jit
609 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Jitter E
610 243095 22639439 10 0.00% 0.00% 0.00% 0 PM Callback
611 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Virtual
612 978 1069 914 0.00% 0.00% 0.00% 0 DCM snmp dp Thre
613 1 3 333 0.00% 0.00% 0.00% 0 snmp dcm ma shim
614 13228 978611 13 0.00% 0.00% 0.00% 0 Bulkstat-Client
615 0 3 0 0.00% 0.00% 0.00% 0 dcm_expression_p
616 47 2510 18 0.00% 0.00% 0.00% 0 EEM Server
617 1 11 90 0.00% 0.00% 0.00% 0 Call Home proces
618 0 3 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
619 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
620 3 13 230 0.00% 0.00% 0.00% 0 EEM ED CLI
621 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Counter
622 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Interface
623 0 4 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
624 0 10 0 0.00% 0.00% 0.00% 0 EEM ED None
625 0 19 0 0.00% 0.00% 0.00% 0 EEM ED OIR
626 0 33 0 0.00% 0.00% 0.00% 0 EEM ED RF
627 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
628 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje
629 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
630 3659 185768 19 0.00% 0.00% 0.00% 0 EEM ED Timer
631 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
632 0 6 0 0.00% 0.00% 0.00% 0 EEM ED Test
633 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Config
634 0 6 0 0.00% 0.00% 0.00% 0 EEM ED Env
635 0 4 0 0.00% 0.00% 0.00% 0 EEM ED DS
636 0 6 0 0.00% 0.00% 0.00% 0 EEM ED CRASH
637 1 6 166 0.00% 0.00% 0.00% 0 EM ED GOLD
638 9897 57590 171 0.00% 0.00% 0.00% 0 Syslog
639 0 8 0 0.00% 0.00% 0.00% 0 PnP-Monitor
640 57 75 760 0.00% 0.00% 0.00% 0 OVLD SPA Backgro
641 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
642 14352 1957159 7 0.00% 0.00% 0.00% 0 VDC process
643 13947 978607 14 0.00% 0.00% 0.00% 0 qos_mon_periodic
644 0 4 0 0.00% 0.00% 0.00% 0 EEM ED RPC
645 0 3 0 0.00% 0.00% 0.00% 0 CTS credentials
646 1 8 125 0.00% 0.00% 0.00% 0 RBM CORE
647 84 10874 7 0.00% 0.00% 0.00% 0 SGACL LOG CORE
648 0 1 0 0.00% 0.00% 0.00% 0 ISSU Utility Pro
649 0 1 0 0.00% 0.00% 0.00% 0 IOXNSE IPC Msg P
650 0 1 0 0.00% 0.00% 0.00% 0 IOXNSE IPC Msg P
2 417539 1957240 213 0.00% 0.00% 0.00% 0 Load Meter
652 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
653 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
654 2 5 400 0.00% 0.00% 0.00% 0 WSMAN Process
655 35 194 180 0.00% 0.00% 0.00% 0 VLAN Manager
656 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
657 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
658 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
659 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
660 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
661 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
662 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
663 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
664 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
665 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
666 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
667 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
668 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
669 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
670 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
671 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
672 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
673 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
674 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
675 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
676 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
677 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
678 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
679 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
680 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
681 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
682 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
683 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
684 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
685 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
686 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
687 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
688 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
689 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
690 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
691 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
692 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
693 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
694 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
695 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
696 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
697 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
698 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
699 1 1 1000 0.00% 0.00% 0.00% 0 IPC ISSU Version
700 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
701 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
702 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
703 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
704 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
705 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
706 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
707 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
708 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
709 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
710 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
711 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
712 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
713 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
714 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
715 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
716 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
717 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
718 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
719 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
720 0 1 0 0.00% 0.00% 0.00% 0 CWAN OIR IPC Rea
721 248219 19563284 12 0.00% 0.00% 0.00% 0 SBC main process
722 0 2 0 0.00% 0.00% 0.00% 0 MRIB Process
723 66 4659 14 0.00% 0.00% 0.00% 0 EEM Helper Threa
724 0 1 0 0.00% 0.00% 0.00% 0 SBC Msg Ack Time
725 0 2 0 0.00% 0.00% 0.00% 0 DiagCard3/-1
726 0 3 0 0.00% 0.00% 0.00% 0 OTV Event Dispat
727 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
728 0 3 0 0.00% 0.00% 0.00% 0 SBC RF config sy
729 257934 38185326 6 0.00% 0.00% 0.00% 0 CCM Subscriber P
730 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
731 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
732 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
733 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
734 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch XD
735 0 1 0 0.00% 0.00% 0.00% 0 XOS async sync X
1 0 155 0 0.00% 0.00% 0.00% 0 Chunk Manager
369 0 9 0 0.00% 0.00% 0.00% 0 MLDSN-HA
378 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology
739 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
740 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
741 1380 6834 201 0.00% 0.00% 0.00% 0 SNMP Traps
742 0 3 0 0.00% 0.00% 0.00% 0 RADIUS
743 129273 1639056 78 0.00% 0.00% 0.00% 0 LLDP Protocol
744 74546 2115686 35 0.00% 0.00% 0.00% 0 LACP Protocol
745 61480 9782904 6 0.00% 0.00% 0.00% 0 DHCP Client
746 0 1 0 0.00% 0.00% 0.00% 0 SNMP Manager
747 62501 4903187 12 0.00% 0.00% 0.00% 0 SACRcvWQWrk3
748 0 1 0 0.00% 0.00% 0.00% 0 SNMP Proxy Forwa
749 242082 9935101 24 0.00% 0.00% 0.00% 0 NTP
750 722 163105 4 0.00% 0.00% 0.00% 0 NTP Auxiliary Pr
751 280 6098 45 0.00% 0.00% 0.00% 0 TACACS+
752 0 2 0 0.00% 0.00% 0.00% 0 SpanTree Helper
753 0 7 0 0.00% 0.00% 0.00% 0 Process to do EH
754 2 15 133 0.00% 0.00% 0.00% 0 RFS server proce
755 0 1 0 0.00% 0.00% 0.00% 0 EM Action CNS
382 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Inp
757 0 1 0 0.00% 0.00% 0.00% 0 Network Synchron
758 2 34 58 0.00% 0.00% 0.00% 0 KEYSTORE HA IPC
759 113719 1127410 100 0.00% 0.00% 0.00% 0 SISF Switcher Th
760 90321 5155535 17 0.00% 0.00% 0.00% 0 SASRcvWQWrk2
761 476114 38217483 12 0.00% 0.00% 0.00% 0 SISF Main Thread
762 0 1 0 0.00% 0.00% 0.00% 3 SSH Process
This command only shows processes inside the IOS daemon.
Please use 'show processes cpu platform sorted'
to show processes from the underlying operating system.
WLC# tern i le
WLC# ter
WLC# terminal le
WLC# terminal length 0
WLC#sh proc
WLC#sh processes cp
WLC#sh processes cpu p
WLC#sh processes cpu platform so
WLC#sh processes cpu platform sorted
CPU utilization for five seconds: 10%, one minute: 10%, five minutes: 10%
Core 0: CPU utilization for five seconds: 1%, one minute: 4%, five minutes: 4%
Core 1: CPU utilization for five seconds: 2%, one minute: 4%, five minutes: 4%
Core 2: CPU utilization for five seconds: 2%, one minute: 4%, five minutes: 4%
Core 3: CPU utilization for five seconds: 1%, one minute: 1%, five minutes: 1%
Core 4: CPU utilization for five seconds: 1%, one minute: 1%, five minutes: 1%
Core 5: CPU utilization for five seconds: 3%, one minute: 3%, five minutes: 3%
Core 6: CPU utilization for five seconds: 1%, one minute: 1%, five minutes: 1%
Core 7: CPU utilization for five seconds: 100%, one minute: 99%, five minutes: 100%
Core 8: CPU utilization for five seconds: 0%, one minute: 0%, five minutes: 0%
Core 9: CPU utilization for five seconds: 0%, one minute: 0%, five minutes: 0%
Core 10: CPU utilization for five seconds: 0%, one minute: 0%, five minutes: 0%
Pid PPid 5Sec 1Min 5Min Status Size Name
19546 19528 108% 109% 108% S 315540 ucode_pkt_PPE0
20649 20629 1% 1% 1% R 231456 fman_fp_image
4068 3996 1% 4% 4% S 1411408 linux_iosd-imag
32475 2 0% 0% 0% I 0 kworker/u32:2-events
29923 29916 0% 0% 0% S 19548 ngiolite
29916 21943 0% 0% 0% S 5948 pman
29683 29655 0% 0% 0% S 5676 nginx
29682 29655 0% 0% 0% S 19884 nginx
29655 29645 0% 0% 0% S 12700 nginx
29645 3663 0% 0% 0% S 5988 pman
29497 29492 0% 0% 0% S 18592 ngiolite
29492 21943 0% 0% 0% S 5808 pman
29192 13910 0% 0% 0% S 244 sleep
27423 2 0% 0% 0% S 0 SarIosdMond
26076 26062 0% 0% 0% S 71508 iomd
26062 21943 0% 0% 0% S 5884 pman
25515 25497 0% 0% 0% S 69832 iomd
25497 21943 0% 0% 0% S 5904 pman
24632 2 0% 0% 0% I 0 kworker/u32:1-flush-
24264 24250 0% 0% 0% S 37092 cmcc
24250 21943 0% 0% 0% S 6016 pman
23886 23872 0% 0% 0% S 22964 hman
23872 21943 0% 0% 0% S 5992 pman
22367 21943 0% 0% 0% S 260 inotifywait
22211 1 0% 0% 0% S 3548 rotee
21943 1 0% 0% 0% S 10592 pvp.sh
20856 20842 0% 0% 0% S 34572 cman_fp
20842 18537 0% 0% 0% S 6024 pman
20629 18537 0% 0% 0% S 5840 pman
20515 20498 0% 0% 0% S 5520 journalctl
20498 20491 0% 0% 0% S 18368 plogd
20491 3663 0% 0% 0% S 5916 pman
20400 20391 0% 0% 0% S 287256 cpp_cp_svr
20391 18537 0% 0% 0% S 5936 pman
20282 20271 0% 0% 0% S 259388 repm
20271 3663 0% 0% 0% S 5824 pman
20175 20164 0% 0% 0% S 85240 cpp_sp_svr
20164 18537 0% 0% 0% S 5960 pman
20029 20018 0% 0% 0% S 29200 service_mgr
20018 3663 0% 0% 0% S 5952 pman
19970 19955 0% 0% 0% S 66580 cpp_driver
19955 18537 0% 0% 0% S 5948 pman
19804 19794 0% 0% 0% S 124576 smand
19794 3663 0% 0% 0% S 5964 pman
19751 19737 0% 0% 0% S 75644 cpp_ha_top_leve
19737 18537 0% 0% 0% S 5840 pman
19528 18537 0% 0% 0% S 6008 pman
19519 19506 0% 0% 0% S 184752 sessmgrd
19506 3663 0% 0% 0% S 5940 pman
19216 19202 0% 0% 0% S 125572 psd
19202 3663 0% 0% 0% S 6024 pman
19095 19082 0% 0% 0% S 25772 service_mgr
19082 18537 0% 0% 0% S 5976 pman
18898 18886 0% 0% 0% S 212224 mobilityd
18886 3663 0% 0% 0% S 5912 pman
18882 18537 0% 0% 0% S 260 inotifywait
18739 1 0% 0% 0% S 3644 rotee
18661 18649 0% 0% 0% S 170944 nmspd
18649 3663 0% 0% 0% S 5988 pman
18537 1 0% 0% 0% S 10440 pvp.sh
18464 18456 0% 0% 0% S 175200 rogued
18456 3663 0% 0% 0% S 5912 pman
18321 18312 0% 0% 0% S 186036 rrm
18312 3663 0% 0% 0% S 5968 pman
18202 18195 0% 0% 0% S 480804 wncd_0
18195 3663 0% 0% 0% S 5964 pman
18059 18049 0% 0% 0% S 401224 wncmgrd
18049 3663 0% 0% 0% S 5900 pman
17913 17905 0% 0% 0% S 109288 wstatsd
17905 3663 0% 0% 0% S 5976 pman
17521 17514 0% 0% 0% S 226428 cli_agent
17514 3663 0% 0% 0% S 5900 pman
17439 17424 0% 0% 0% S 1964 sntp
17424 1 0% 0% 0% S 2792 stack_sntp.sh
17316 2 0% 0% 0% S 0 NFSv4 callback
17280 17265 0% 0% 0% S 50392 cloudm
17265 3663 0% 0% 0% S 5984 pman
17073 17055 0% 0% 0% S 352824 dbm
17055 3663 0% 0% 0% S 5912 pman
16690 16672 0% 0% 0% S 155600 fman_rp
16672 3663 0% 0% 0% S 5944 pman
16489 16470 0% 0% 0% R 27876 hman
16470 3663 0% 0% 0% S 6004 pman
16078 16070 0% 0% 0% S 96424 odm_1
16070 3663 0% 0% 0% S 5948 pman
15840 15824 0% 0% 0% S 188792 odm_0
15824 3663 0% 0% 0% S 5988 pman
15501 15477 0% 0% 0% S 34096 odm_proxy
15477 3663 0% 0% 0% S 5844 pman
14234 14219 0% 0% 0% S 13108 periodic.sh
14219 3663 0% 0% 0% S 5984 pman
14000 13986 0% 0% 0% S 41256 pistisd
13986 3663 0% 0% 0% S 5948 pman
13910 13906 0% 0% 0% S 15636 paed-maintenanc
13906 3663 0% 0% 0% S 5900 pman
13785 3663 0% 0% 0% S 6448 pman
13777 13768 0% 0% 0% S 2932 sort_files_by_i
13768 3663 0% 0% 0% S 5972 pman
13681 13319 0% 0% 0% S 264 inotifywait
13319 13303 0% 0% 0% S 18244 auto_upgrade_cl
13303 3663 0% 0% 0% S 5828 pman
12735 12721 0% 0% 0% S 45052 install_mgr
12721 3663 0% 0% 0% S 5944 pman
12592 12147 0% 0% 0% S 268 inotifywait
12588 12147 0% 0% 0% S 17352 issu_stack.sh
12586 12147 0% 0% 0% S 264 inotifywait
12584 12147 0% 0% 0% S 16740 issu_stack.sh
12582 12147 0% 0% 0% S 268 inotifywait
12147 12133 0% 0% 0% S 18396 issu_stack.sh
12133 3663 0% 0% 0% S 5952 pman
11876 11426 0% 0% 0% S 264 inotifywait
11712 11693 0% 0% 0% S 24784 lman
11693 3663 0% 0% 0% S 5988 pman
11426 11393 0% 0% 0% S 18804 ncd.sh
11393 3663 0% 0% 0% S 5928 pman
11378 13777 0% 0% 0% S 244 sleep
10980 10971 0% 0% 0% S 34056 vman
10971 3663 0% 0% 0% S 5988 pman
10458 3663 0% 0% 0% S 264 inotifywait
10437 10007 0% 0% 0% S 264 inotifywait
10416 10024 0% 0% 0% S 260 inotifywait
10392 1 0% 0% 0% S 3724 rotee
10319 10027 0% 0% 0% S 260 inotifywait
10298 1 0% 0% 0% S 3396 rotee
10211 1 0% 0% 0% S 3724 rotee
10027 1 0% 0% 0% S 8152 selinux_smu.sh
10024 1 0% 0% 0% S 11688 kernel_ftrace.s
10015 1 0% 0% 0% S 2292 xinetd
10010 1 0% 0% 0% S 2384 xinetd
10007 1 0% 0% 0% S 16140 rollback_timer.
10004 1 0% 0% 0% S 3488 auxinit.sh
9809 5087 0% 0% 0% S 1744 inotifywait
9227 14234 0% 0% 0% S 248 sleep
9100 13785 0% 0% 0% S 286100 paed
8828 1 0% 0% 0% S 2264 xinetd
7932 2 0% 0% 0% I 0 kworker/u32:0-events
7469 2 0% 0% 0% I 0 kworker/8:2-events
7127 2 0% 0% 0% S 0 lfts_sar_aux
7098 2 0% 0% 0% S 0 loop1
6836 6608 0% 0% 0% S 260 inotifywait
6723 1 0% 0% 0% S 3512 rotee
6608 1 0% 0% 0% S 8252 iptbl.sh
6161 6040 0% 0% 0% S 260 inotifywait
6137 1 0% 0% 0% S 4040 rotee
6040 1 0% 0% 0% S 9600 reflector.sh
5971 5419 0% 0% 0% S 260 inotifywait
5909 1 0% 0% 0% S 3952 rotee
5677 5421 0% 0% 0% S 240 sleep
5631 2 0% 0% 0% S 0 nfsd
5630 2 0% 0% 0% S 0 nfsd
5629 2 0% 0% 0% S 0 nfsd
5628 2 0% 0% 0% S 0 nfsd
5627 2 0% 0% 0% S 0 nfsd
5626 2 0% 0% 0% S 0 nfsd
5625 2 0% 0% 0% S 0 nfsd
5623 2 0% 0% 0% S 0 nfsd
5621 5601 0% 0% 0% S 41704 rif_mgr
5601 3663 0% 0% 0% S 5924 pman
5588 1 0% 0% 0% S 3728 rotee
5479 2 0% 0% 0% S 0 lockd
5478 2 0% 0% 0% I 0 kworker/u33:1-xprtio
5476 1 0% 0% 0% S 2048 xinetd
5467 1 0% 0% 0% S 28408 libvirtd
5459 1 0% 0% 0% S 2312 rpc.statd
5454 1 0% 0% 0% S 3184 rpc.mountd
5431 1 0% 0% 0% S 1916 rpcbind
5425 1 0% 0% 0% S 11316 virtlogd
5421 1 0% 0% 0% S 4460 oom.sh
5419 1 0% 0% 0% S 9720 droputil.sh
5354 5343 0% 0% 0% S 87424 btman
5343 3663 0% 0% 0% S 5936 pman
5170 5156 0% 0% 0% S 22200 keyman
5156 3663 0% 0% 0% S 5988 pman
5087 1 0% 0% 0% S 14208 chasync.sh
4974 2 0% 0% 0% I 0 kworker/0:0-rcu_gp
4955 4942 0% 0% 0% S 22284 emd
4942 3663 0% 0% 0% S 5784 pman
4779 4772 0% 0% 0% S 11048 tam_svcs_esg_cf
4772 3663 0% 0% 0% S 5928 pman
4669 4662 0% 0% 0% S 13420 tams_proc
4662 3663 0% 0% 0% S 5856 pman
4560 4552 0% 0% 0% S 13928 tamd_proc
4552 3663 0% 0% 0% S 5860 pman
4376 4369 0% 0% 0% S 46764 cmand
4369 3663 0% 0% 0% S 5920 pman
4212 2 0% 0% 0% I 0 edac-poller
4178 4165 0% 0% 0% S 38068 stack_mgr
4165 3663 0% 0% 0% S 5800 pman
3996 3663 0% 0% 0% S 5976 pman
3773 1 0% 0% 0% S 4016 rotee
3741 2 0% 0% 0% I 0 qat_fatal_error
3740 2 0% 0% 0% I 0 qat_device_rese
3669 2 0% 0% 0% S 0 lsmpi-rx
3668 2 0% 0% 0% S 0 lsmpi-xmit
3667 2 0% 0% 0% S 0 lsmpi-refill
3663 1 0% 0% 0% S 11616 pvp.sh
3658 3582 0% 0% 0% S 260 inotifywait
3634 1 0% 0% 0% S 3680 rotee
3582 1 0% 0% 0% S 12044 psvp.sh
2117 2 0% 0% 0% I 0 kworker/1:2-cgroup_d
2110 2 0% 0% 0% S 0 loop0
1799 2 0% 0% 0% I 0 kworker/11:1H-kblock
1373 2 0% 0% 0% I 0 kworker/4:1H-kblockd
928 2 0% 0% 0% I 0 kworker/15:1H-kblock
926 2 0% 0% 0% I 0 kworker/5:1H-kblockd
917 2 0% 0% 0% I 0 kworker/14:1H-kblock
377 2 0% 0% 0% I 0 kworker/2:2-rcu_gp
376 2 0% 0% 0% I 0 kworker/9:1H-kblockd
366 1 0% 0% 0% S 2032 nfsdcld
365 1 0% 0% 0% S 2072 rpc.idmapd
352 348 0% 0% 0% S 1656 audispd
348 1 0% 0% 0% S 2296 auditd
345 2 0% 0% 0% I 0 kworker/7:2-events
344 2 0% 0% 0% I 0 kworker/7:1H-kblockd
343 2 0% 0% 0% I 0 kworker/12:1H-kblock
340 2 0% 0% 0% I 0 kworker/3:1H-kblockd
338 2 0% 0% 0% I 0 kworker/6:1H-kblockd
335 2 0% 0% 0% I 0 kworker/2:1H-kblockd
334 2 0% 0% 0% I 0 kworker/0:1H-kblockd
307 2 0% 0% 0% I 0 kworker/8:1H-kblockd
284 2 0% 0% 0% I 0 kworker/1:1H-kblockd
283 2 0% 0% 0% I 0 kworker/13:1H-kblock
282 2 0% 0% 0% I 0 kworker/10:2
281 2 0% 0% 0% I 0 kworker/10:1H-kblock
265 1 0% 0% 0% S 6628 systemd-udevd
258 2 0% 0% 0% I 0 kworker/12:2-rcu_gp
237 2 0% 0% 0% I 0 kworker/13:2-events
214 2 0% 0% 0% I 0 kworker/15:2-events
212 2 0% 0% 0% I 0 kworker/3:2-events
189 1 0% 0% 0% S 7632 systemd-journal
182 2 0% 0% 0% S 0 usb-storage
181 2 0% 0% 0% I 0 scsi_tmf_6
180 2 0% 0% 0% S 0 scsi_eh_6
176 2 0% 0% 0% I 0 kworker/4:2-events
175 2 0% 0% 0% I 0 kworker/5:2-rcu_gp
174 2 0% 0% 0% I 0 kworker/6:2-mm_percp
167 2 0% 0% 0% I 0 ipv6_addrconf
166 2 0% 0% 0% I 0 dm_bufio_cache
162 2 0% 0% 0% I 0 scsi_tmf_5
161 2 0% 0% 0% S 0 scsi_eh_5
160 2 0% 0% 0% I 0 scsi_tmf_4
159 2 0% 0% 0% S 0 scsi_eh_4
158 2 0% 0% 0% I 0 scsi_tmf_3
157 2 0% 0% 0% S 0 scsi_eh_3
156 2 0% 0% 0% I 0 scsi_tmf_2
155 2 0% 0% 0% S 0 scsi_eh_2
154 2 0% 0% 0% I 0 scsi_tmf_1
153 2 0% 0% 0% S 0 scsi_eh_1
152 2 0% 0% 0% I 0 scsi_tmf_0
151 2 0% 0% 0% S 0 scsi_eh_0
150 2 0% 0% 0% I 0 tpm-vtpm
149 2 0% 0% 0% I 0 acpi_thermal_pm
148 2 0% 0% 0% I 0 kworker/15:1-events
147 2 0% 0% 0% I 0 kworker/14:1-events
146 2 0% 0% 0% I 0 kworker/13:1-events
145 2 0% 0% 0% I 0 kworker/12:1-events
144 2 0% 0% 0% I 0 kworker/11:1-events
143 2 0% 0% 0% I 0 kworker/9:1-events
142 2 0% 0% 0% I 0 kworker/8:1-mm_percp
141 2 0% 0% 0% I 0 kworker/7:1-events_p
140 2 0% 0% 0% I 0 kworker/6:1-mm_percp
139 2 0% 0% 0% I 0 kworker/5:1-mm_percp
138 2 0% 0% 0% I 0 kworker/4:1-events
137 2 0% 0% 0% S 0 irq/31-aerdrv
136 2 0% 0% 0% S 0 irq/29-aerdrv
135 2 0% 0% 0% S 0 irq/28-aerdrv
134 2 0% 0% 0% S 0 irq/27-aerdrv
133 2 0% 0% 0% S 0 irq/25-aerdrv
131 2 0% 0% 0% I 0 nfsiod
130 2 0% 0% 0% S 0 kswapd0
129 2 0% 0% 0% I 0 kworker/10:1-rcu_gp
128 2 0% 0% 0% I 0 kworker/2:1-mm_percp
127 2 0% 0% 0% I 0 xprtiod
126 2 0% 0% 0% I 0 kworker/u33:0-xprtio
125 2 0% 0% 0% I 0 rpciod
124 2 0% 0% 0% S 0 watchdogd
123 2 0% 0% 0% I 0 md
122 2 0% 0% 0% I 0 tpm_dev_wq
121 2 0% 0% 0% I 0 kblockd
106 2 0% 0% 0% I 0 kworker/3:1-events
96 2 0% 0% 0% S 0 kcompactd0
95 2 0% 0% 0% I 0 writeback
94 2 0% 0% 0% S 0 oom_reaper
93 2 0% 0% 0% S 0 khungtaskd
92 2 0% 0% 0% I 0 kworker/1:1-mm_percp
91 2 0% 0% 0% I 0 kworker/0:1-events
90 2 0% 0% 0% S 0 kauditd
89 2 0% 0% 0% I 0 netns
88 2 0% 0% 0% S 0 kdevtmpfs
87 2 0% 0% 0% I 0 kworker/15:0H-kblock
85 2 0% 0% 0% T 0 ksoftirqd/15
84 2 0% 0% 0% T 0 migration/15
83 2 0% 0% 0% T 0 cpuhp/15
82 2 0% 0% 0% I 0 kworker/14:0H-kblock
81 2 0% 0% 0% I 0 kworker/14:0-events
80 2 0% 0% 0% T 0 ksoftirqd/14
79 2 0% 0% 0% T 0 migration/14
78 2 0% 0% 0% T 0 cpuhp/14
77 2 0% 0% 0% I 0 kworker/13:0H
75 2 0% 0% 0% T 0 ksoftirqd/13
74 2 0% 0% 0% T 0 migration/13
73 2 0% 0% 0% T 0 cpuhp/13
72 2 0% 0% 0% I 0 kworker/12:0H-kblock
70 2 0% 0% 0% T 0 ksoftirqd/12
69 2 0% 0% 0% T 0 migration/12
68 2 0% 0% 0% T 0 cpuhp/12
67 2 0% 0% 0% I 0 kworker/11:0H-kblock
66 2 0% 0% 0% I 0 kworker/11:0-events
65 2 0% 0% 0% T 0 ksoftirqd/11
64 2 0% 0% 0% T 0 migration/11
63 2 0% 0% 0% T 0 cpuhp/11
62 2 0% 0% 0% I 0 kworker/10:0H-kblock
60 2 0% 0% 0% S 0 ksoftirqd/10
59 2 0% 0% 0% S 0 migration/10
58 2 0% 0% 0% S 0 cpuhp/10
57 2 0% 0% 0% I 0 kworker/9:0H
56 2 0% 0% 0% I 0 kworker/9:0-events
55 2 0% 0% 0% S 0 ksoftirqd/9
54 2 0% 0% 0% S 0 migration/9
53 2 0% 0% 0% S 0 cpuhp/9
52 2 0% 0% 0% I 0 kworker/8:0H-kblockd
50 2 0% 0% 0% S 0 ksoftirqd/8
49 2 0% 0% 0% S 0 migration/8
48 2 0% 0% 0% S 0 cpuhp/8
47 2 0% 0% 0% I 0 kworker/7:0H-kblockd
45 2 0% 0% 0% S 0 ksoftirqd/7
44 2 0% 0% 0% S 0 migration/7
43 2 0% 0% 0% S 0 cpuhp/7
42 2 0% 0% 0% I 0 kworker/6:0H-kblockd
40 2 0% 0% 0% S 0 ksoftirqd/6
39 2 0% 0% 0% S 0 migration/6
38 2 0% 0% 0% S 0 cpuhp/6
37 2 0% 0% 0% I 0 kworker/5:0H
35 2 0% 0% 0% S 0 ksoftirqd/5
34 2 0% 0% 0% S 0 migration/5
33 2 0% 0% 0% S 0 cpuhp/5
32 2 0% 0% 0% I 0 kworker/4:0H-kblockd
30 2 0% 0% 0% S 0 ksoftirqd/4
29 2 0% 0% 0% S 0 migration/4
28 2 0% 0% 0% S 0 cpuhp/4
27 2 0% 0% 0% I 0 kworker/3:0H-kblockd
25 2 0% 0% 0% S 0 ksoftirqd/3
24 2 0% 0% 0% S 0 migration/3
23 2 0% 0% 0% S 0 cpuhp/3
22 2 0% 0% 0% I 0 kworker/2:0H-kblockd
20 2 0% 0% 0% S 0 ksoftirqd/2
19 2 0% 0% 0% S 0 migration/2
18 2 0% 0% 0% S 0 cpuhp/2
17 2 0% 0% 0% I 0 kworker/1:0H-kblockd
15 2 0% 0% 0% S 0 ksoftirqd/1
14 2 0% 0% 0% S 0 migration/1
13 2 0% 0% 0% S 0 cpuhp/1
12 2 0% 0% 0% S 0 cpuhp/0
11 2 0% 0% 0% S 0 migration/0
10 2 0% 0% 0% I 0 rcu_sched
9 2 0% 0% 0% S 0 ksoftirqd/0
8 2 0% 0% 0% I 0 mm_percpu_wq
6 2 0% 0% 0% I 0 kworker/0:0H-kblockd
4 2 0% 0% 0% I 0 rcu_par_gp
3 2 0% 0% 0% I 0 rcu_gp
2 0 0% 0% 0% S 0 kthreadd
1 0 0% 0% 0% S 28528 systemd
THANKS
MANISH MANWAL
Snmp is crash ap.
Try disable it or use trap instead
MHM
Core 7 is hot-spinning.
CSCve73211, CSCwh10989, CSCwh75934
Leo Laohoo
What firmware is the controller on?
In the controller, post the complete output to the following command:
dir bootflash:*.crash
Firmware 17.9.5
WLC#dir bootflash:*.crash
Directory of bootflash:/*.crash
73593 -rw- 122879 Jan 24 2025 09:18:58 +00:00 sjc2-acc-wap02_087b87a95a80.crash
73597 -rw- 102884 Jan 14 2025 23:14:57 +00:00 sjc2-acc-wap13_087b87a96a60.crash
73598 -rw- 105325 Jan 16 2025 19:30:49 +00:00 sjc2-acc-wap15_087b87a9d2a0.crash
73599 -rw- 111972 Jan 23 2025 18:33:30 +00:00 sjc2-acc-wap12_087b87aac0e0.crash
73600 -rw- 102920 Jan 14 2025 21:12:46 +00:00 sjc2-acc-wap01_087b87a98680.crash
73601 -rw- 88690 Jan 10 2025 20:12:20 +00:00 sjc2-acc-wap07_087b87a95a00.crash
73602 -rw- 125723 Jan 22 2025 22:22:52 +00:00 sjc2-acc-wap14_087b87a9e760.crash
73603 -rw- 104756 Jan 7 2025 15:22:49 +00:00 sjc2-acc-wap06_087b87a95980.crash
73604 -rw- 94748 Jan 8 2025 02:44:38 +00:00 sjc2-acc-wap03_087b87a96180.crash
73605 -rw- 96480 Dec 19 2024 01:26:11 +00:00 sjc2-acc-wap05_087b87a99020.crash
73606 -rw- 96036 Jan 22 2025 23:23:52 +00:00 sjc2-acc-wap08_087b87a95e80.crash
73607 -rw- 91457 Jan 23 2025 22:27:47 +00:00 sjc2-acc-wap11_087b87a96540.crash
73608 -rw- 121101 Jan 15 2025 21:58:28 +00:00 sjc2-acc-wap10_087b87a96b40.crash
73609 -rw- 97337 Jan 16 2025 21:53:14 +00:00 sjc2-acc-wap04_087b87a9ee00.crash
73610 -rw- 102333 Jan 7 2025 20:58:25 +00:00 sjc2-acc-wap09_087b87a95ce0.crash
26458804224 bytes total (13534035968 bytes free)
THANKS
MANISH MANWAL
 - Consider 17.12.4 and try again,
 M.
Please share this file.
PFA
THANKS
MANISH MANWAL
Like what @Rich R mentioned, typical with software issue/bug.
<2>[01/22/2025 23:20:25.6673] kernel BUG at /san1/BUILD/workspace/c179_throttle_17_9_5_47_CCO/label/ap1g6a/base/build_axel-qca/wlan-11.0-build/os/linux/../../cmn_dev/qdf/linux/src/qdf_trace.c:4121!
<0>[01/22/2025 23:20:25.7373] Internal error: Oops - BUG: 0 [#1] SMP
If you have a spare WLC, you can always test with that controller with an later code version that supports all the ap's in your environment. Testing is the only way for you to make sure that when you do upgrade or install a SP, that you don't run ingto any other issues and that the issue you are experiencing is resolved.
-Scott
<0>[01/22/2025 23:20:34.2673] Kernel panic - not syncing: Fatal exception in interrupt
<2>[01/22/2025 23:20:34.3373] CPU2: stopping
<4>[01/22/2025 23:20:34.3373] CPU: 2 PID: 7478 Comm: grpc_server Tainted: P      D     E   4.4.60 #1
AP crashed due to kernel picnic (intentional misspelled -- Leo) due to GRPC.
I strongly recommend daily reboot of the APs because there are more than a hundred AP crashes due to "kernel panic".
marce1000
  - Check software version being used on the controller; go for 17.12.4 , especially if you are using an older
     version,
 M.
version is 17.9.5
THANKS
MANISH MANWAL
Rich R
AP crashes are almost always caused by bugs in the AP software, and there are a lot of them.
The only way to resolve these is by upgrading to fixed software (very rarely by turning off certain features).
Update to 17.12.4 with APSP7 installed to resolve as many AP crash bugs as possible - there will still be more, but that resolves a lot of AP crashes.
I have a few TAC cases open for various different AP crashes.
As Leo says - the AP crash file will tell us what is causing the crash but you might need TAC to decode it for you if the cause is not obvious from the crash file.
Compare all the crash files - they might all be the same cause or you might see multiple different causes.
