WAP reboot due to crash
Manish Manwal
we have wlc 9800 and having multiple AP connected to it. sometime we get the logs that wap reboot due to crash. can anyone help. WAP model: CW9166I-B
Jan 22 23:23:30.901: %APMGR_TRACE_MESSAGE-3-WLC_AP_LOG_MSG: Chassis 2 R0/0: wncd: AP Remote Log: 087b.87a9.xxxx Last AP wap08 reboot was due to crash
THANKS
MANISH MANWAL
19 Replies 19
Scott Fella
If you have another controller, try to move the ap's to that and then make sure you have syslog, so you can filter on specific logs.  Logging can help you also determine if its happening to certain ap's, how often and maybe any triggers before the crash.  If some ap's do not crash at all, I have seen in the past where the image was corrupted in the ap and deleting that image and letting the ap pull the image back has fixed the issue.  It really comes down to how much time to you have to play around and test, vs updating and hopefully improving the user experience.  AP's crashing is a hard fail on the clients and that will cause poor user experience, so figure out how much time you plan on testing before you just decide to patch/upgrade they system.
You can do what @Leo Laohoo mentioned, but look at your syslog filters to see if these ap's crash multiple times a day.  Gather more data to help you with your decision.
-Scott
we have controller with HA.
THANKS
MANISH MANWAL
HA meaning SSO or N+1? If you don’t have a spare controller or able to spin up a 9899-CL VM to test, then the only thing you can do is open a TAC case and let them guide you on your next steps. If it is a bug, you will need to upgrade or patch.
-Scott
Manish Manwal
Raising the case with Cisco Tech. will update here whatever Tech suggest.
THANKS
MANISH MANWAL
Let see if I was correct abd it issue of SNMP.
Plesse update us
Thanks a lot
MHM
