WAP1852e - Control radios programmatically
dspringer1177
Community Member
Hello Community,
Can someone help me out? I have some 1852e wireless APs running Mobility Express and need to have a way to enable and disable both radios programatically. Is there any kind of API that allows access into the AP and change radio states? I'm envisioning either sending an SNMP string, or something wrapped in xml. I'm trying to get a room AV control system to turn the radios on and off with a push button instead of cutting power to the AP and forcing it to reload every time it comes back.
Derrick
keglass
Level 11
Level 11
Derrick,
Thank you for posting to the community. I recommend you also post this to the Cisco Support Community for additional information and feedback.
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
