Can access HTTPS to WLC 2504 other than 'management' interface
johnlloyd_13
Level 11
Level 11
hi all,
per subject, is it possible to HTTPS to WLC using other interface?
we plan to NAT to a public IP the VLAN 2 interface for our vendor's access.
so far i could ping from my home internet but can't HTTPS.
Please use the below links may be help you
https://supportforums.cisco.com/document/102661/troubleshooting-network-access-telnetsshhttphttps-wireless-lan-controller
https://supportforums.cisco.com/discussion/11859111/web-access-wlc-management
hi,
thanks for the links. i saw we can enable HTTPS access on the dynamic interface used by SSID/WLAN but can this be access from outside (internet) and NOT from a wireless LAN client.
b. Additionally, you can use the following command to access the controller via the dynamic interface mapped to the ssid/wlan the wireless client is connecting on:
(Cisco Controller) > config network mgmt-via-dynamic-interface enable
(Cisco Controller) >show network summary
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Enable
