WAP321 connect issue
TupeloIT
Community Member
I have a WAP321 and I am unable to connect to it nor can i access the internet when connected directly to it
Hi Sharon,
Have you followed the quick start guide as link below
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/quick_start/guide/WAP_121_321_QSG.pdf
regards
Richard
mohanak
Try to reset the device to factory defaults:
To reset the device to factory default settings:
• To restore the device to the factory default settings, with the power on,
press-and-hold the Reset button with a bent paperclip for more than 10
seconds. (12-13 seconds usually works well)
– All of the lights will go off.
– Release the Reset button when power light turns on.
Configuration Guide : http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
