WAP321 will not pass IP's
mikerocom1
My network is as follows:
Motorola 3515 cable moded==>Cisco 2851==>Cisco 3750
I have a WAP321 connected to gig1/0/3 of the 3750. I am replacing a Egenius WAP. It works, its just a crappy AP and needs to be restarted several times a day so I replaced it with the 321.
interface GigabitEthernet1/0/3
 description WAP
 switchport mode trunk
WAP321 setup:
Static IP:
10.10.17.3
255.255.255.0
10.10.17.1
Vlan 10 is my primary network
Vlan 30 is my guest wireless network
Primary SSID is mikero
     Vlan ID 10
Guest SSID is mikero_guest
     Vlan ID 30
My wireless devices connect to the WAP however the WAP will not pass an IP to anything.
Attached are my router and switch configs.
did you ever resolve this? I have WAP561 with the same problem, no idea what's going on.
