watchdog reset in WLC 5508 7.4.100.60
nomair_83
Level 3
Level 3
Hi ,
Last week we found that primary WLC was hanged so we need to reboot it.
As per logs:
Last Reset....................................... Watchdog reset
We are using 7.4.100.60.
Any idea what could be the root cause.
2 Accepted Solutions
Scott Fella
Just to add...
Make sure you have upgraded the FUS since your on v7.4. You should be on at least FUS 1.8.0.0. There is also a newer FUS 1.9.0.0 but only required if your on v7.6.x. The FUS can be installed on v7.4 but optional.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.pdf
-Scott
Rasika Nayanajith
Check your WLC serial number as well, if it starts FCW1614 or later then it may be due to this bug as well.
CSCul68057
Symptom:
Wireless LAN Controller may encounter unexpected reload without crash file or coredump.
Console log output may include "reaperWatcher rebooting" and "!!!!! Watchdog detected LOCKUP !!!!!",
and there may be "#OSAPI-2-REAPER_WATCHER_INFO" message in syslog.
Conditions:
5508, 2504 or WiSM2 manufactured after April 2012.
Affected S/N: FCW1614xxxx and later
This is due to incompatibility of previous driver with some of the flash components used after that date
Workaround:
None, upgrade to one of the recommended software versions
Anyway your choices are very limited now, only 3 WLC software codes supported by Cisco 7.0.250.0(7.0MR5), 7.4.121.0 (7.4MR2) and 7.6.101.x(7.6MR1). So upgrade to 7.4.121.0 code as that is the highly recommended code at the moment. See below for more details
https://supportforums.cisco.com/docs/DOC-40178
I would suggest to go for FUS 1.9.0.0 as well.
Rasika
*** Pls rate all useful responses ****
Sandeep Choudhary
must be hitting a bug: CSCug65454
Upgrade to version 7.4.121.0
Dont forget to rate helpful posts
Scott Fella
Just to add...
-Scott
Rasika Nayanajith
CSCul68057
Symptom:
Conditions:
Workaround:
Rasika
Hi Rasika,
We have this problem too.
Last reset by watchdog reset. But we are using 7.3.112.0 that known fixed release on bug CSCul68057.
Any idea what the problem?
