Wireless - access points
Pravin Pillai
Level 3
Level 3
Hi ,
I have a question. Can we find out about the type of antenna used in an AP by logging into AP. I am looking for any physical survey or assessment. I am looking for is a bunch of commands which could be used to identify the antenna type by issuing these commands on AP
Sandeep Choudhary
There is no command for these:
You will have to physically inspect it.
Since the antenna will just convert it into electromagnetic wave, there is no way to determine what is the type of antenna that is connected to the AP.
In addition under the radio interface of the AP (aIOS) or on the WLC you can label the antenna you are using.
Over CLI on aIOS APs, under the radio there is this options
"antenna gain ____"
on WLC under each radio settings, there is he option and it is even available on the WCS.
hope it helps!
Dont forget to rate helpful posts
Sandeep Choudhary
You can find out the anteena name and number from WCS or NCS .
In WCS/NCS , you can not only label your antenna type, but you can actually choose it from a pull down menu.
kaaftab
Level 9
Level 9
No you cannot do with ios command but i would suggest that you follow the data sheet for supported antennas and by looking at them you can easly find the type of antenna used with the AP.
