{watchdogd} Process capwapd no heartbeat for 60s Error on 1560
shrijan
I have a cisco 1560 outdoor AP. While i boot the device i found the error below and could not join to WLC.
!!!!! {watchdogd} Process capwapd no heartbeat for 60s
Any Help..
6 Replies 6
Scott Fella
Take a look at the bug search tool or just do an internet search for your error to help you understand what it means.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvj44939
-Scott
Hi Scott,
Does it mean the AP is totally gone? I meant cannot be repair.
regards,
shrijan
Well you can always RMA the ap if you have a support contract. You can’t fix everything. Look through other bugs or internet searches and see if there is a fix, I don’t know.
-Scott
That bug CSCvj44939 is a *software* bug - upgrading to a fixed version will resolve that.
But just because you have a similar error does not guarantee that bug is the cause of the problem.
Upgrade to a fixed version (eg 8.10.142.0) - if you still see the problem then open a TAC case.
You did not mention what version of software you're using - you should always mention all relevant info including the software release you're using.
Hi rrudling,
Thank you for the advice.
I am totally new on this WLC..
I guess below is the version you are talking about:
AP Running Image : 8.5.151.0
Primary Boot Image : 8.5.151.0
Backup Boot Image : 8.5.131.0
Let me try upgrading the version.
Thank You all for the advice.
regards,
shrijan
Hi rrduling,
Do you have any link or doc that i can follow to upgrade my ap?
Thanks.
shrijan
