WCS 4404 LAG - CDP From 6500 - Strange output
kfarrington
Level 3
Level 3
Guys,
I have two 4404s connected to two different 6500 switches.
They have two ports connect to each switch in LAG mode. Lets say 1/1 and 2/1 on the 6500s.
When I do a show cdp nei from the 6500, on port 1/1 I see two entries showing the local interface as 1/1 and the remote interfaces being unit 0 slot 0 port 1 and unit 0 slot 0 port 2.
On port 2/1 i see no cdp neighbor entries?
Is this normal and just cosmetic?
Thx
Ken
Scott Fella
You have the etherchannel setup correctly on the 6500?
-Scott
Yes it is. It is very strange :)
How do you have the etherchannel setup and the port-channel. You should see cdp on both ports.
What is the output on the show etherchannel
-Scott
