Wireless Controller and security
wim_depauw
Level 3
Level 3
One of our companies is implementing a wireless network . We would like to do the following :
- For conference rooms we would like to have a separate wireless network which has access to internet . All pc's that are not from the company should be able to connect.
PC's that are from the company should not be able to use the wireless connection.This wireless network should be setup without authentication.
- Secure wireless connection : Company pc's should only use the secure wireless network .
I was thinking about using mobility groups but that doesn't block a company pc going to the unsecured wireless network and connect himself .
I'm not an expert in wireless so hopefully I'm not asking a stupid question 🙂
gr
wim
Scott Fella
You can use vlan override to allow certain ssid's on certain ap's. To block company pc's from accessing the guest network, you can either use a webauth and create a username and password that is only given out to guest and not internal users. Antoher way is to lock down the wireless through group policy.
-Scott
