04-05-2011 09:57 AM - edited 07-03-2021 08:02 PM
I´m trying to edit the maps of my buildings but i only see a white image on the map editor. I've already tried with png and jpg, also i've tried reducing dpi from 96dpi to 72dpi and to 32dpi but i always get the white image.
I have other WCS with previous version, and the strange thing is that a image that is ok for editing in the previous version of the WCS is not working in this latest version.
04-06-2011 09:41 AM
What is the pixel size H x W? Send over the file to me at sschmidt@cisco.com and I will give it a go in the lab.
04-07-2011 12:28 AM
I have some more information, the WCS where everything is working fine is version 7.0.164.0, so i took the same images i used there (campus, outdoor an indoor) and tried on the new WCS version 7.0.164.3 and when i open the map editor it seems to load the image but it is not shown, ¿should i download version?
I attached one of the images i used that is working on 7.0.164.0 but not on 7.0.164.3.
04-07-2011 07:38 AM
I have tried this on my lab 7.0.164.3 server and am able to see the image in map editor when added as an outdoor area.
Have you tried removing the map completely and adding it again?
04-07-2011 08:17 AM
04-07-2011 08:26 AM
Please go to Administration > Logging and check these log modules:
Configuration
Monitor
General
UI General
Administration
Tools
Then change the message level to TRACE and click submit.
Go back and recreate the issue and then go back to the logging area and download and send over the wcs-0-0.log to sschmidt@cisco.com.
