Unstable Wireless Bridge Connection via 802.11a(Radio 1) of Aironet 1242
EE_36220
I'm going to setup up an AP 1242 in a remote area to support b/g client via a 802.11a bridge link (all using AP 1242).
Before the deployment, I tested the configuration in a lab environment. However, I found the bridge link will come up a while and suddenly gone. Resetting the root AP or the non-root AP cannot bring the connection up again. Sometimes, when I shutdown the b/g radio (radio 0) of the remote AP, the bridge link will be established again. Following is the log from the root AP.
Thanks!
*Apr  4 12:24:05.013: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Apr  4 12:24:05.054: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr  4 12:24:05.665: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
*Apr  4 12:24:06.009: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Apr  4 12:24:06.013: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Apr  4 12:24:07.054: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Apr  4 12:24:16.091: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associa
te: No Response
*Apr  4 12:24:16.811: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Apr  4 12:24:17.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to upInternal error:  command failed                                                             <<<< Internal error:  command failed ??????
        <<<<don't know the meaning of this message
*Apr  4 12:27:22.206: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Apr  4 12:27:22.233: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr  4 12:27:22.233: dot11_mgmt: bad cookie returned from driver for mac 003a.9         <<<<<003a.928.dad0 is radio 1 / non root bridge of remote AP
928.dad0(expected 0x00000000, got 0x010ADAB0) - force driver to delete client             <<<<<don't know the meaning of this message
*Apr  4 12:27:22.235: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Apr  4 12:27:22.262: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr  4 12:27:23.513: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Apr  4 12:27:26.993: %DOT11-6-ASSOC: Interface Dot11Radio1, Station T9_QC168_Ca
ntil 003a.9928.dad0 Reassociated KEY_MGMT[NONE]
*Apr  4 12:27:28.465: %DOT11-4-MAXRETRIES: Packet to client 003a.9928.dad0 reach
ed max retries, removing the client
*Apr  4 12:27:28.465: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating
Station 003a.9928.dad0 Reason: Previous authentication no longer valid
*Apr  4 12:27:28.467: %DOT11-4-MAXRETRIES: Packet to client 003a.9928.dad0 reach
*Apr  4 12:27:31.673: %DOT11-6-ASSOC: Interface Dot11Radio1, Station T9_QC168_Ca
*Apr  4 12:27:32.687: %DOT11-6-ADD: Interface Dot11Radio1, Station 003a.9926.e76
0 Associated to Parent 003a.9928.dad0
*Apr  4 12:28:46.178: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating
Station 003a.9928.dad0 Reason: Sending station has left the BSS
*Apr  4 12:28:46.179: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating
Station 003a.9926.e760
*Apr  4 12:28:46.181: %DOT11-6-ASSOC: Interface Dot11Radio1, Station T9_QC168_Ca
*Apr  4 12:28:47.196: %DOT11-6-ADD: Interface Dot11Radio1, Station 003a.9926.e76
*Apr  4 12:29:15.132: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Apr  4 12:29:32.442: %DOT11-4-MAXRETRIES: Packet to client 003a.9928.dad0 reach
*Apr  4 12:29:32.442: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating
*Apr  4 12:29:32.443: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating
*Apr  4 12:29:32.444: %DOT11-4-MAXRETRIES: Packet to client 003a.9928.dad0 reach
*Apr  4 12:31:10.285: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associa
te: Rcvd response from 003a.9928.2660 channel 6 2560
*Apr  4 12:31:18.286: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associa
te: AssociatingInternal error:  command failed
*Apr  4 12:31:27.021: dot11_mgmt: bad cookie returned from driver for mac 003a.9
928.2660(expected 0x00000000, got 0x010ADAB0) - force driver to delete client
*Apr  4 12:31:29.107: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associ
ated To AP T9_SML_LT2_AP2 003a.9928.2660 [None]
*Apr  4 12:31:29.108: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr  4 12:31:30.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
I guess it should be better to ask the full show tech and show log from both units, how many antennas, and  what antennas its using at each side, distance...
5 Replies 5
Surendra BG
Please post the Root and the Non root config here..
Surendra
Surendra BG
Thanks dmantill for reminding me to revisit the antenna and related stuff.
As the setup is in a lab environment, the APs are put on a work bench next to each other, therefore, the radio output power was lowered.
After adjusting the output powers, it works as expected.
Thanks Surendra and dmantill.
Hey, thats nice to hear!! thanks for posting on CSC !!
Surendra BG
GREAT! please rate the post and mark it as solved!
http://farm3.static.flickr.com/2061/2306127707_2607857c2d.jpg
