Bookmark
Subscribe
852
WCS and ACS
sbarasiscom
Can I install WCS and ACS in the same machine and run them at the same time
5 Replies 5
Jagdeep Gambhir
Level 10
Level 10
Hi ,
This configuration is not recommended because of shared common ports used by both service. There are a lot of hidden port values that can not be modified. I've tested this personally and having WCS and ACS on the same box is not a reliable setup.
Jagdeep
Note : If that helps then please mark it resolved so that other can benefit.
diro
i'm running wcs 4.1 and acs 4.0 on the same windows 2003 server for the cuwn course without any problem. Knowing that cisco required this as a lab setup, i can't believe their will be port problems.
Do you use VM ware and what is the specifications of the server
I'm running the free vmware server on a shuttle PC (SN27P2) athlon based (AMD Athlon 64 X2 socket AM2 3800+) with 4GB of ram however the vitual machine only gets 1GB of ram. And is only using 1 processor.
elkono200
hi
i'm using Windows 2003 Server with WCS and ACs on the same machine... without any problems...
bye
