08-08-2008 05:28 AM - edited 07-03-2021 04:18 PM
I'm having trouble understanding how to set antenna orientation.
We have an outdoor mesh consisting of 1500's. When I add APs to a WCS outdoor map and attempt to set the antenna azimuth and elevation the resultant heat maps don't look right...
The antennas are mounted to a pole 65' in the air with both antennas pointed at the ground.
Any recommendations on how to set azimuth and elevation ?
TIA,
dave moreland
08-08-2008 06:24 AM
Here is a link that will help:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/wifich5.html#wp1052591
Here are some from the forum:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Security%20and%20Network%20Management&topicID=.ee6e8c0&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc07dc3/2#selected_message
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Security%20and%20Network%20Management&CommCmd=MB?cmd=pass_through&location=outline@^1@@.1ddbfd2c/1#selected_message
08-08-2008 06:44 AM
So, if I understand, the azimuth should be set to 0 degrees for an omni (this is confirmed in the release notes as well).
I'm still having trouble with the elevation; 0-180 degrees, either up or down. Can you recommend settings for an AP, 65 from the ground on a pole with the antennas pointed at the ground ?
