wcs configuration problem
vladskuba
Community Member
Hi, all!
I'm trying to configure auto startup of Wireless Control System on Red Hat ES 5.1 runlevel 5. But any manipulations with init scripts doesn't help.
Can anyone provide a solution?
Also I have a problem with starting WCS on runlevel 3, but on runlevel 5 all works fine.
Thanks to all of you.
scottwilliamson
Level 5
Level 5
Hi Vladislav,
It looks as though Red Hat 5.1 is not a supported operating system:
http://www.cisco.com/en/US/docs/wireless/wcs/release/notes/WCS_RN5_0.html#wp44427
Scott
krengasw
Hi ,
WCS won't support red hat ES 5.1.it supports Red hat ES 4.0 update 5 or advanced server 4.0 update 5.
Be aware that since most deployments sold use Windows, there are limited resources supporting the advancement of Linux as a platform. I know, this bites, but it is simply economics.
