WCS Failover
nitsg.gupta
Level 2
Level 2
what happens if the WCS goes down. wireless network will continue to work or it will also go down.
wesleyterry
Level 7
Level 7
The WLC's will go on doing their own thing. If WCS goes down, the only thing you lose is your ability to maintain all of the WLCs from a central location (and location services, if you use it). There might be lobby ambassador issue, but the bottom line is that the WLC will still continue to work.
