WCS Maps Conversion
kwonza
Level 3
Level 3
Looking for a good program to convert AUTOCAD .dwf files into .jpg for importing into WCS. Having issues with Visio. Thanks
bwalchez
Level 8
Level 8
Visio is the only option
There are a lot of better options than Visio. One program I have tried is Any .dwg to jpg. See the following link. There are others too, most have evals so you can see which has the most options you need. Each works a little differently. Just google for "+.dwg +convert +jpg" for more options.
http://anydwg.com/
Thanks, was able to output .jpg in AUTOCAD 2007 using the command line.
