12-10-2010 08:20 AM - edited 07-03-2021 07:31 PM
I have a APs setup in my 11 story building on all the even floors starting with floor 2. I have added the maps for all 11 floors into a building setup in our WCS. However I am not seeing the heat signatures on the odd floors in which I would expect to see them after putting in the right dimensions in the building/floor config(s). Is there something I am missing in order for the heat signatures to show up on the odd floors from the even floor APs? Below is info on my equipment/software:
WCS 6.0.170.0
AP Type | CAPWAP |
AP Model | AIR-LAP1252AG-A-K9 |
IOS Version | 12.4(23c)JA |
Thanks in Advance!
Solved! Go to Solution.
12-13-2010 09:27 AM
To set a maximum to the AP height I think, which in turn is used to modify the heatmap considering that heatmaps are at ground level.
Nicolas
12-11-2010 02:23 AM
Hi Jeremy,
heatmaps are not calculated in 3 dimensions. WCS can't know your floor height, neither the attenuation of the floor so it can't compute on a floor the heatmaps of APs placed on other floors.
Hope this clarifies.
Nicolas
Don't forget to rate answers that you find useful
12-13-2010 07:18 AM
So what is the purpose of the WCS asking for floor height then?
12-13-2010 09:27 AM
Nicolas
