WCS Reports issues
DocHolden
Community Member
The reports in WCS are very inadequate.  If the report is over 100,000 records I can't run it.  I can't customize the reports like I need to also.  Is there a way to make these reports work better?  Can I export the whole database into something else in order to get the infomation out that I need?  Any ideas would be very helpful.  Thanks in advance.
aronmatushenko
Community Member
This is still an issue. Running WCS 7.1.91.0. Annoying trying to pull a 1 week client summary on a 138AP network and I can't get the report to run. 100k should be easy by modern standards. Especially after having a few years and multiple versions of WCS to work through the bug...
