11-17-2010 06:00 AM - edited 07-03-2021 07:25 PM
Hi All,
a Customer wants to Upgrade his WCS from 6.0.196.0 to 7.0.164.0, this seems not to be supported. Do they have to downgrade at first to 6.0.181.0, which is marked as Supported in the Release Notes or is there an other way?
Rgrds, Michael
Solved! Go to Solution.
11-17-2010 06:41 AM
Hi Michael,
I completely understand your concerns .. the Developemt team is working on it actively and we will come with the resolution for this by max early next year
currently we have 2 options..
Option 1
Either to reinstall the 6.0.181 and then reconfigure the same and then go to 7.0
Option 2
Directly install 7.0 on a new machine and reconfigure the database.
Surendra
11-17-2010 06:22 AM
Hi Michael,
Cisco doesnot recommend downgrading.. you cannot downgrade the WCS software either AFAIK.
So you have to reinstall WCS with supported version and restore its backup prior to upgrading
then upgrade to version 7.0. That is, we need to have the Back up of 6.0.181, install the 6.0.181 fresh and restore the back up and then upgrade it to 7.0
If there is currently no backup from previous version, you have to reinstall it and reconfigure WCS,
this is a known issue
I request you to let me know how this answered your question
Surendra
11-17-2010 06:36 AM
Hi Surendra, thx for your answer, i run scared about the content...
We installed the WCS in July, were this Release was Up to date, so we dont have a Backup from an older Version. So my Customer will not accept that there is no Upgrade path. My Customer is a Large Hospital, 2 Campuses with 4 WiSMs and 500 APS, a lot of Maps and Templates, so there will be no way to Reinstall and Reconfigure it.
Any more Ideas?
Greetings, Michael
11-17-2010 06:41 AM
Hi Michael,
Option 1
Option 2
Surendra
11-17-2010 07:31 AM
Surendra, I don´t know if is possible but will it work the following???
- Make a backup for the version 6.0.196.0
- Uninstall this version and install version 6.0.181.0
- Restore the backup of version 6.0.196.0, if it works, make a new backup for the database with the version 6.0.181.0 format.
- Uninstall 6.0.181.0 and install version 7.0.164.0.
- Restore the 6.0.181.0 backup.
If the 3rd step works, It would be possible upgrade from the first version to 7.0
Best Regards.
11-17-2010 07:40 AM
Hi Raul,
You wouldnt be able to downgrade as well. If we have the back up of 6.0.181 then ONLY its possible.
we have a backup of 6.0.181, then install that version > restore from backup and then upgrade to 7.0
we are working on this to get it resolved ASAP
Surendra
11-17-2010 08:57 AM
lemme know how that answered ur question!!
Surendra
