WDS and Access Point Authentication. How does it work ?
ciscoprolin
Dear All,
APs can be authenticated through WDS against a Radius Server. But how can they authenticate without a username and a password in the Radius DB ? In the WDS settings there is nowhere a field where you can enter a username/pw of a user defined on the Radius Server !??
Thanks for your feedback.
Stephen Rodriguez
You do need to have an entry in the DB for the username password of the AP. If I remember correctly the entry on the client AP is made under, Wireless Services > AP, here you can define the WDS username the AP will send. Alternately, you can use the CLI command of:
wlccp ap username < name > password 0 < password >
Referenced from here:
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.3_2_JA/configuration/guide/s32roamg.html#wp1051791
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Dear colleague,
just one more question on this - how can it be that the AP gets authenticated anyway - even if I do not enter the username/password under Wireless Services --> AP (and not via the IOS CLI) ?
Thorsten
