WDS Authentication with ACS Constantly
raun.williams
Level 3
Level 3
We are a fairly large campus with approximately 150 AP's. Currently we are NOT lightweight and have deployed WDS's to locations under the 'recommanded/required' standards.. However, it seems that our WDS's seem to constantly authenticate to the ACS server for AP authentication, not user. They pass on authentication, but it seems to be constant and it fills up the logs and makes it a mess to dig through them for other issues. Is there a time out that can be upped on authentication for this?
thomas.chen
Level 6
Level 6
I think this can be adjusted using the reauthentication timer on the RADIUS server. For information on configuring the WDS feature read http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml
Any idea where this option is located. I've looked over the WDS doc before and again just now. It mentions the reauthentication interval (though I think it may only apply to clients) but I don't see where it says to adjust the setting.
Thank you
