Web auth plus encryption
Peter Nugent
We have a client who is currently using web auth however he must secure his network. Currently I am at a loss as to the best way to go about this and keep the convenience of web auth.
I think some of his clients should go into a seperate database and use PEAP, however he does still need web auth.
Client devices are general contractor laptops, XP etc with Windows zero config.
Has anyone got any ideas for this
dancampb
Level 11
Level 11
You can use encryption with webauth but it can't be a radius based authentication.  You could use either static WEP or one of the WPA PSK versions.
