Web Authentication Bundle
Roger Alderman
Level 5
Level 5
Hi All
I am currently playing aound with the WLC Web Auth Bundle.
I need to do Guest Access using a Proxy Server so obviously the Web Auth doesn't work unless you configure the client to locally bypass the 1.1.1.1 address. This isn't practical for the clients so I was thinking of using the Web Passthrough function.
I have successfully downloaded the Web Auth bundle that gives me an acceptable usage policy page and the login page with an entry for the client's email address. I now want to edit the login page and then download the Web Auth bundle again.
Does anyone know how to overwrite or delete the existing Web Auth bundle on the WLC?
Thanks everyone.
Roger
Surendra BG
  • Does anyone know how to overwrite or delete the existing Web Auth bundle on the WLC?
ANS - Currently no way.. we have raised the enhancement request and the bug ID is CSCtf51294 and the link as well..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf51294
The bug is resolved and will be out in next 7.0 Release..
As of now, we can try downloading the new Web auth bundle and then this may overwrite the existing one..
Surendra
Surendra BG
