Web Authentication Certificate issue
kendo.igor
Level 3
Level 3
We are running Cisco WLC 4402, OS version 4.1.185.0.
I'm trying to add a certificate for WebAuth. I run the following command and get this error:
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ Site Cert
TFTP Server IP................................... 192.168.21.43
TFTP Packet Timeout.............................. 4
TFTP Max Retries................................. 2
TFTP Path........................................ /
TFTP Filename.................................... final.pem
This may take some time.
Are you sure you want to start? (y/N) y
TFTP Webauth cert transfer starting.
Web Authentication Certificate file transfer failed - Error from server: Access
I'm confident that the tftp server is fine. I can download the file from another PC.
Thanks.
dennischolmes
Level 11
Level 11
What TFTP server are you using? Needs to be 32mb I believe. The new Solarwinds supports this.
You have to make sure you enter a password when generating the cert and when you tftp, you need to have that password enterd or else it will fail. Been there done that... hope that helps.
-Scott
Oooops. Yep. Didn't think to mention that.
