Web Authentication logout window
talmadari
Level 3
Level 3
i'm trying to find out if i can customize the web authentication logout web page?
can i disable it?
THX,
Scott Fella
5.2 will allow you to customize the logout web page, but you can't disable it. Any code prior to 5.2 will not allow you to customize the logout page.
-Scott
Well i'm currently running 5.2.157, which by the way runs better then 5.0.x.
I can customize the login page but not the logout window (which is popup)
Here is a link to look at. Hope this helps.
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52users.html#wp1075664
-Scott
