Web authentication on autonomous WAPs?
jasonww04
Level 5
Level 5
Is it possible to do the web authentication redirect using stand-alone 1131s or is that feature only available with WLAN controllers?
pcroak
Web-authentication is a solution for a Unified (WLC) environment only. Autonomous APs cannot perform this functionality.
-Patrick Croak
Wireless TAC
pcroak
-Patrick Croak
Wireless TAC
George Stefanick
Jason,
You can purchase 3rd party boxes like the nomadix which allows you to get a functional guest services.
http://www.nomadix.com/
