Web authentication users failed?
rguzman.plannet
Level 5
Level 5
I have a guest network and lately I have been experiencing troubles with some users.
The symptom, as I create a username and password and type'em in a laptop the authentication fields in the web authentication page don't keep the data as if I didn't type anything
WLC 4402-50
Version 7.0.98.210
Hope someone can help.
Thanks!
7 Replies 7
Nicolas Darchis
What kind of OS and browser ?
Richard Atkin
Level 10
Level 10
Are you using the WLC internal captive portal page or one hosted on a third-party device?  Also, are you using any SSL Certificates and/or DNS on the Virtual Interface?
Rich
Sorry for the delay I am out of office so I can't check updates that often.
I am using internal web authentication page, and certificates crated by the WLC and no I am not using DNS.
It happens only to some users, it can work or not in the same computer depending on which user name are we typing in.
Regards!
Here is an update of my case, I captured a debugg from a devie trying to connect to guest wlan with two different usernames and passwords. The firts didnt work but as soon as I tried another one it connected.
I was looking for some document that mentions something about "Orphan Packet", don't know what that means. I typed some comments below in the capture please notice them.
(Cisco Controller) >debug client d8:9e:3f:84:f8:aa
(Cisco Controller) >*apfMsConnTask_0: May 27 11:12:30.991: Deleting the client immediatly since WLAN is changed
*apfReceiveTask: May 27 11:12:47.960: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:47.967: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.001: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.013: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.019: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.038: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.514: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.518: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.531: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.541: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.550: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:12:48.560: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*spamReceiveTask: May 27 11:13:11.348: CCKM: Send CCKM cache entry
*apfReceiveTask: May 27 11:13:42.871: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:13:42.885: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:13:42.889: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:13:42.895: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:13:42.901: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*apfReceiveTask: May 27 11:13:42.904: d8:9e:3f:84:f8:aa Orphan Packet from 192.168.1.173 on mobile
*emWeb: May 27 11:13:43.023: d8:9e:3f:84:f8:aa Username entry (robertwireless) created for mobile <-- Here you can see when I tried with a username that does work. The loggs after that changed to the ones when I tried with the other username.
*emWeb: May 27 11:13:43.024: d8:9e:3f:84:f8:aa Setting guest session timeout for mobile d8:9e:3f:84:f8:aa to 1641958 seconds
*emWeb: May 27 11:13:43.024: d8:9e:3f:84:f8:aa Session Timeout is 1641958 - starting session timer for the mobile
*emWeb: May 27 11:13:43.024: d8:9e:3f:84:f8:aa 192.168.1.173 WEBAUTH_REQD (8) Change state to WEBAUTH_NOL3SEC (14) last state WEBAUTH_NOL3SEC (14)
*emWeb: May 27 11:13:43.024: d8:9e:3f:84:f8:aa apfMsRunStateInc
*emWeb: May 27 11:13:43.024: d8:9e:3f:84:f8:aa 192.168.1.173 WEBAUTH_NOL3SEC (14) Change state to RUN (20) last state RUN (20)
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa Session Timeout is 1641958 - starting session timer for the mobile
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa 192.168.1.173 RUN (20) Reached PLUMBFASTPATH: from line 4796
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa 192.168.1.173 RUN (20) Replacing Fast Path rule
  type = Airespace AP Client
  on AP 00:18:74:4b:d5:80, slot 0, interface = 1, QOS = 0
  ACL Id = 255, Jumbo Frames = N
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa 192.168.1.173 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 5006  IPv6 Vlan = 17, IPv6 intf id = 8
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa 192.168.1.173 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*emWeb: May 27 11:13:43.025: d8:9e:3f:84:f8:aa Updating guest account information for user robertwireless at login.
Hi guys,
Have you managed to solve this issue? As I am facing the same  problem as well?
Thanks and Regards,
Kanes.R
Not an official solution if you are running the same IOS go ahead and upgrade it.
