Web Authnetcation WLC
ricardorojas123
Level 7
Level 7
In the web authentication of the wireless lan controller 4400 series, I can set the hours of navigation for users?
ricardorojas123
Level 7
Level 7
If you are adding a new user, check the Guest User check box if you want to limit the amount of time
that the user has access to the local network. The default setting is unchecked.
