Web External format for WLC 5508
Hi guys!
We have a external web in php and it not works. I can't find info for supported web format in WLC 5508, version 7.0.25X
In HTML format works flawlessly.
Passthrough -> External Redirect.
ACL is ok.
Thanks for your help!
David Watkins
Level 4
Level 4
The question doesn't quite make sense.  Is this an external WebAuth page or an internal WebAuth page?  For internal, you're going to have to stick with basic HTML/CSS.  If it's an external page, then you can use whatever you want, so long as you include the required data provided by Cisco in their WebAuthBundle file (ie. form/actions/script items).  It would make no sense that you cannot use PHP or any other server side technologies on an "external" page because the WLC would have nothing to do with it.
