Web-redirect to external radius not wokring on some browsers for Guest SSID
Lovleen Arora
We are using Cisco 5760 with 3.7, and the guest SSID doesn't perform web-redirect to external radius (cisco NAC appliance), for some browsers. Although the same works on Cisco 5508 and 4402 WLC with the same NAC appliance for all browsers.
working browsers: IE9.0 and IE 11.0
Non-working: Chrome all versions, Firefox all versions, Safari all versions.
Can anyone provide some help if they have seen  this issue before.?
Abhishek Abhishek
You need to check the compatibility guide of Cisco WLC and check if those browsers are supported or not.
