Webauth asking again for credntials
ittechk4u
Community Member
Hello Experts,
I am having an issue with webauth page.
I am using ISE as radius server and using sponsor account for guest account creation.
My Issue is: once I login with webauth i got internet connection but after few idle time (5-10min), I need to enter username and password again.
Can this problem can be solved??? I have guest acount for 1 year timepeariod and I dont want to enter crenditals again and again.
Is there any solution?
wlc- 2504, AP- 2602, ISE 1.1 version
5 Accepted Solutions
Scott Fella
Set the idle timer on the WLC to something like 7200 seconds or 14400 seconds. That will allows devices I stay idle for that long before having to login again.
-Scott
Sandeep Choudhary
adding to above
You can set the session timeout up to 24 hours. That's the max and webauth users will have no other option than re-login every day.
If you want a guest PC to stay connected for longer periods, I doubt that the guest portal solution is the best for your use case.
Reagrds
Dont forget to rate helpful posts
I dont think you can do it permanently with WLC.
Reagrds
The issue is with certain devices especially Apple. The session timer has to be a higher value than the idle timer. You can use the sleeping client feature if you are just using WebAuth.
http://www.cisco.com/en/US/docs/wireless/controller/7.5/config_guide/b_cg75_chapter_0111100.html
Session timer is a hard timeout and you can leave that disabled and it default to 24 hours. The idle timer is how long you want the WLC to keep the device in the RUN state.
-Scott
As long as a client entry is not removed from the WLC, it should not have to re web-auth.
Session timeout is a hard stop, so yes you could limit the session timeout to 12 hours. The other problem is that the WLC will "remove" a client by default after 5 minutes of an AP not hearing from the client. So a client who is shut down, or in power-save (no wireless packets), will be deauthenticated after the idle timeout period.
The user idle timeout is when you shut down laptop, or move away, so no deauthenticate frame was sent the client just goes silent. The idle timeout defines how long the WLC waits before deleting the client entry when it's not hearing AT ALL a single frame from the client.
But still I feel this is not you want, you want permanent connection to guest users but I think it is not possible now.
Hope it helps.
Reagrds
9 Replies 9
Scott Fella
-Scott
With the later code versions of the WLC, you can define this on the WLAN advanced tab instead of globally in the GUI Controller tab.
-Scott
Cant I do it permanently that it never ask username and password till my account expires ??
Reagrds
-Scott
Hope it helps.
Reagrds
Sandeep Choudhary
adding to above
Reagrds
OK Thanks sandep & Scott
You guys are really great.
Reagrds
Just remember with Apple devices, it's when the device scene closes that the idle timer starts counting down. With Apple devices, I also way keep the session timer niche he and have the idle timer set at 7200 or 14400. This allows users to go to lunch etc and come back without logging back on. I would make sure that your on a code that allows this to be configured on the WLAN and not global. This can cause issues when using FlexConnect mode and keeping users in the run state.
-Scott
