Webauth bundle issue
Anyone know the structure of a page on java, cause i have a problem to download the .tar is this correct on the structure???
blakekrone
Level 9
Level 9
webauth bundles have strict requirements, one of them being under 1MB. You also can't really get all fancy with any type of programming languages.
I would recommend looking under the 5508 WLC download section on CCO for the examples and start from there.
Scott Fella
Have you looked at the code for the default webauth or download the webauth bundle form CCO? You can use that HTML code and modify that to your liking. There is also a document on the forum regarding webauth but I don't have the link for that.
Scott Fella
Sent from my iPhone
-Scott
Hi guys thanks for both answers my client and i just try to download on the wlc the page but its on java no on javascript... the wlc support java or only javascript??? Exist any document or page where shows how programming this page on javascript or java???
Regards!!!
Both Scott and I pointed you to the examples, they are on CCO under the WLC downloads.
The page only supports javascript.
