WEP Key Conversion
volyashevsky
Community Member
Please advise on how to convert 128-bit alphanumeric WEP key used by Orinoco Cards in the form of 13-character acii string e.g.: cisco87654321 to a 26-character HEX string acceptable by 1200 IOS AP.
Thank you.
dixho
Level 11
Level 11
Go to www.google.com and search for ASCII hex conversion. You will find the table to ASCII and hexdecimal conversion table. e.g. cisco87654321 is 636973636f3837363534333231.
