Wireless Cisco 350. With Windwos XP Pro SP2
jorgerozas
My name is Jorge Rozas. I need help with a wireless cisco 350 series with windows XP Sp2. The Wireless working great but pull out power cord, the conection fail, and lost my ip adresss. the message is "Limited or no Conectivivity".
The machine is a Laptop IBM R32, with windows XP SP2. The problem is in all Laptops because in my office exist 200 laptop IBM R32 y the problem its the same in all others.
Sorry for my English.
thanks.
Jorge Rozas Vargas
IT Systems Department
Markham College
ebreniz
Level 6
Level 6
The most common cause of this behavior is the inability of the PC to communicate with the card through the PCMCIA socket. Check the driver for your PC Card socketif it is a CardBus driver, it is most likely 32-bit only. The Cisco Aironet card requires 16-bit access, and if the driver for the socket only works in 32-bit mode, you must contact the manufacturer of the laptop for a 16-bit version. If they cannot provide you with one, there are third-party PCMCIA card and socket service manufacturers who sell products that do support 16-bit access.
http://www.cisco.com/warp/public/102/wlan/windows-clients-faq.html
http://www.cisco.com/warp/public/102/wlan/connectivity.html
