WGB AP1300 : Line protocol on Interface Dot11Radio0, changed state to down
Abmas Sidi
Hi everybody
I have a problem with a WGB AP1300 whose Dot11Radio0 interface automatically turn to DOWN once Root AP connectivity is lost.
Here's my environment :
I have several WGB AP1300. Each WGB is installed on a Bus in order to connect Ethernet equipments (PC's) on the bus. As buses are mobile, roaming is enabled on the WGB AP. The WGB is connected to a AP3502i (Root AP) managed by a WLC5508 controller.
Once started the WGB AP works fine, PC's in the bus can connect succefully to the main Network infrastructure.
The proble occurs when the bus moves out of the WiFi coverage area, connectivity is lost (that's normal) and then comes back to the WiFi coverage area. The  WiFi connectivity is not restablished (no re-association), between the WGB AP and the Root AP. And I observe that the status of the Dot11Radio0 is DOWN. I've tried the commad line with no success:
AP1300_1(config)# int d0
AP1300_1(config-if)# no shutdown
AP1300_1(config-if)# exit
Restaring the WGB AP1300 did not solve my problem.
I get on the following log errors on the WGB AP1300 :
    Interface Dot11Radio0, cannot associate: No Response
    Interface Dot11Radio0, parent lost: Too many retries
Can anyone help me please.
Many thanks.
Abmas
The config of the WGB AP1300 is :
version 12.3
no service pad
service password-encryption
hostname AP1300_1
enable secret 5 $1$vDNk$N2pPvLVGRfCv8R5f/gn1Y.
ip subnet-zero
ip domain name mydomain.com
ip ssh version 2
no aaa new-model
dot11 ssid MySSID
  authentication open
  authentication key-management wpa
  wpa-psk ascii 7 105D1D1644191D1D0D063F38
username admin privilege 7 secret 5 $1$jlwK$ll1c3f.qEblnWj/hExNeC1
bridge irb
interface Dot11Radio0
no shutdown
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid MySSID
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role workgroup-bridge
mobile station period 20 threshold 70
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address XX.XX.XX.XX 255.255.255.0
no ip route-cache
ip default-gateway XX.XX.XX.XX
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
bridge 1 aging-time 86400
line con 0
line vty 0 4
login local
transport input ssh
workgroup-bridge client-vlan XX
end
Amjad Abdullah
Hi Abmas,
First, what is the exact security configuration on the controller's SSID? Are you have bot WPA and WPA2 enabled on the controller with both TKIP and AES enabed? I see you only have WPA-TKIP configured on the WGB.
I would suggest that you give a look into the controller and see what is the status of the WGB there.
In controller's CLI you can also enabled debugs to see the process of the associatoin of the WGB.
Enable the following debugs on the WLC CLI and let the WGB try again to enter the coverage area:
debug client .
After taking sometime and the WGB does not associate while it is in the coverage area, issue this command:
show client detail
Provide us with the output of the above command. that will possibly point a finger to where the issue resides.
Amjad
Rating useful replies is more useful than saying "Thank you"
8 Replies 8
Amjad Abdullah
Hi Abmas,
debug client .
show client detail
Amjad
Hi Amjad,
On the controller's SSID security conf, I've only enabled WPA-TKIP.
Also folowing your instruactions, I've enabled debugging on the WLC CLI for the concerned WGB. Here are the outputs of the "show client detail " command.
1- First output : the WGB is in the WiFi coverage area and it's successfully associated to the (root) AP.
2 - Second Output : the WGB came back to in the WiFi coverage area and it's NOT associated anymore to the (root) AP. After a while the output of the command is "Invalid Client MAC address provided".
Hope those outputs let you known the source of my problem.
Once again many thanks.
Abmas
(Cisco Controller) >debug client
(Cisco Controller) >show client detail
Client MAC Address...............................
Client Username ................................. N/A
AP MAC Address...................................
AP Name..........................................
Client State..................................... Associated
Client NAC OOB State............................. Access
Workgroup Bridge................................. 2 client(s)
Wireless LAN Id.................................. 3
BSSID............................................
Connected For ................................... 221 secs
Channel.......................................... 1
IP Address.......................................
Association Id................................... 2
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Session Timeout.................................. 1800
Client CCX version............................... 1
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
WMM Support...................................... Enabled
Power Save....................................... OFF
--More-- or (q)uit
Current Rate..................................... 11.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
ACL Name......................................... none
ACL Applied Status............................... Unavailable
Policy Type...................................... WPA1
Authentication Key Management.................... PSK
Encryption Cipher................................ TKIP-MIC
Management Frame Protection...................... No
EAP Type......................................... Unknown
Interface........................................ vlanXX
VLAN............................................. XX
Quarantine VLAN.................................. 0
Access VLAN...................................... XX
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
--More-- or (q)uit
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 200
      Fast BSS Transition........................ Not implemented
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 38701
      Number of Bytes Sent....................... 8473
      Number of Packets Received................. 278
      Number of Packets Sent..................... 33
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of Data Retries..................... 32
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 13
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -87 dBm
      Signal to Noise Ratio...................... 10 dB
Nearby AP Statistics:
--More-- or (q)uit
      (slot 0) .................
antenna0: 10 seconds ago -86 dBm................. antenna1: 10 seconds ago -83 dBm
2 - Second Output :the WGB came back to in the WiFi coverage area and it's NOT associated anymore to the (root) AP.
Connected For ................................... 880 secs
--More-- or (q)uit
Current Rate..................................... 48.0
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 75003
      Number of Bytes Sent....................... 12486
      Number of Packets Received................. 852
      Number of Packets Sent..................... 48
      Number of Data Retries..................... 125
      Number of Duplicate Received Packets....... 19
      Radio Signal Strength Indicator............ -88 dBm
      Signal to Noise Ratio...................... 69 dB
--More-- or (q)uit
antenna0: 0 seconds ago -92 dBm.................. antenna1: 0 seconds ago -92 dBm
antenna0: 1 seconds ago -92 dBm.................. antenna1: 1 seconds ago -93 dBm
Can anyone help us ?
Thanks.
Abmas
Hello Ambas,
Both output show that WGS is OK! actually the command output while the WGB is not supposed to be working shows that the WGB in good status!!
Can you please allow sometime after the WGB enters the area again before taking the output?
Also, there is no debug output! can you please enable the debug client again and collect the output? I can see no output from the above.
One quick quesion: are we sure that the WGB leaves the covered area completely? i.e. are the radio interface on the WGB become in down status before it come back to the coverage again?
Amjad
Hi Amjad,
- When I allow a while after the WGB enters the WiFi area, the output of the
show client detail is : "Invalide client MAC address provided".
Indeed the MAC address of the WGB is no longer in the list of the associated clients on the WLC.
- Yes I am sure that the WGB leaves completely the area. During the bus movement (leaving the area), I launch a continous ping from my laptop (connected to the LAN side of the WGB) to Server (connected to the LAN side of the Root AP). And ping starts failing once the bus is outside of the WiFi area. At that time I check the WGB Radio interface status and it's Down. Coming back to the WiFi area, it reamains Down.
I took two (2) Debug Outputs.
- First one : The WGB is in the WiFi area (associated)
- Second one :The WGB has left the WiFi area (disassociated)
====== First output : The WGB is in the WiFi area (associated) =======================
*pemReceiveTask: Feb 04 15:15:22.322: Removed NPU entry.
*apfMsConnTask_0: Feb 04 15:15:22.322: AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Feb 04 15:15:22.322: 8021X_REQD (3) DHCP required on AP vapId 3 apVapId 3for this client
*apfMsConnTask_0: Feb 04 15:15:22.322: Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Feb 04 15:15:22.322: 8021X_REQD (3) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*apfMsConnTask_0: Feb 04 15:15:22.322: apfPemAddUser2 (apf_policy.c:223) Changing state for mobile on AP from Associated to Associated
*apfMsConnTask_0: Feb 04 15:15:22.322: Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_0: Feb 04 15:15:22.322: Sending Assoc Response to station on BSSID (status 0) ApVapId 3 Slot 0
*apfMsConnTask_0: Feb 04 15:15:22.322: apfProcessAssocReq (apf_80211.c:5241) Changing state for mobile on AP from Associated to Associated
*dot1xMsgTask: Feb 04 15:15:22.324: Creating a PKC PMKID Cache entry for station (RSN 0)
*dot1xMsgTask: Feb 04 15:15:22.324: Initiating WPA PSK to mobile
*dot1xMsgTask: Feb 04 15:15:22.324: dot1x - moving mobile into Force Auth state
*dot1xMsgTask: Feb 04 15:15:22.324: Skipping EAP-Success to mobile
*dot1xMsgTask: Feb 04 15:15:22.324: Starting key exchange to mobile , data packets will be dropped
*dot1xMsgTask: Feb 04 15:15:22.324: Sending EAPOL-Key Message to mobile
                              state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.331: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.331: Received EAPOL-key in PTK_START state (message 2) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.331: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.331: Sending EAPOL-Key Message to mobile
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: apfMs1xStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: L2AUTHCOMPLETE (4) DHCP required on AP vapId 3 apVapId 3for this client
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.335: Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: apfMsRunStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: RUN (20) Reached PLUMBFASTPATH: from line 4864
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP , slot 0, interface = 1, QOS = 0
  ACL Id = 255, Jumbo Frames = NO
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  IPv6 Vlan = 99, IPv6 intf id = 14
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: Key exchange done, data packets from mobile should be forwarded shortly
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.336: Sending EAPOL-Key Message to mobile
                                    state PTKINITDONE (message 5 - group), replay counter 00.00.00.00.00.00.00.02
*pemReceiveTask: Feb 04 15:15:22.336: Added NPU entry of type 1, dtlFlags 0x0
*spamApTask0: Feb 04 15:15:22.336: Sent EAPOL-Key M5 for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.345: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.345: Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile
66*Dot1x_NW_MsgTask_6: Feb 04 15:15:22.345: Stopping retransmission timer for mobile
*apfMsConnTask_0: Feb 04 15:16:08.174: Reassociation received from mobile on AP
*apfMsConnTask_0: Feb 04 15:16:08.174: Received association request from a work-group bridge (WGB)!
*apfMsConnTask_0: Feb 04 15:16:08.174: RUN (20) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1621)
*apfMsConnTask_0: Feb 04 15:16:08.174: Applying site-specific IPv6 override for station - vapId 3, site 'default-group', interface 'vlan99'
*apfMsConnTask_0: Feb 04 15:16:08.174: Applying IPv6 Interface Policy for station - vlan 99, interface id 14, interface 'vlan99'
*apfMsConnTask_0: Feb 04 15:16:08.174: STA - rates (8): 130 132 139 12 18 150 24 36 48 72 96 0 0 0 0 0
*apfMsConnTask_0: Feb 04 15:16:08.174: STA - rates (11): 130 132 139 12 18 150 24 36 48 72 96 0 0 0 0 0
*apfMsConnTask_0: Feb 04 15:16:08.174: Processing WPA IE type 221, length 24 for mobile
*apfMsConnTask_0: Feb 04 15:16:08.174: apfMsRunStateDec
*apfMsConnTask_0: Feb 04 15:16:08.174: apfMs1xStateDec
*apfMsConnTask_0: Feb 04 15:16:08.174: RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Feb 04 15:16:08.174: START (0) Initializing policy
*apfMsConnTask_0: Feb 04 15:16:08.174: START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Feb 04 15:16:08.175: AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Feb 04 15:16:08.175: Removed NPU entry.
*apfMsConnTask_0: Feb 04 15:16:08.175: 8021X_REQD (3) DHCP required on AP vapId 3 apVapId 3for this client
*apfMsConnTask_0: Feb 04 15:16:08.175: Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Feb 04 15:16:08.175: 8021X_REQD (3) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*apfMsConnTask_0: Feb 04 15:16:08.175: apfPemAddUser2 (apf_policy.c:223) Changing state for mobile on AP from Associated to Associated
*apfMsConnTask_0: Feb 04 15:16:08.175: Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_0: Feb 04 15:16:08.175: Sending Assoc Response to station on BSSID (status 0) ApVapId 3 Slot 0
*apfMsConnTask_0: Feb 04 15:16:08.175: apfProcessAssocReq (apf_80211.c:5241) Changing state for mobile on AP from Associated to Associated
*dot1xMsgTask: Feb 04 15:16:08.177: Creating a PKC PMKID Cache entry for station (RSN 0)
*dot1xMsgTask: Feb 04 15:16:08.177: Initiating WPA PSK to mobile
*dot1xMsgTask: Feb 04 15:16:08.177: dot1x - moving mobile into Force Auth state
*dot1xMsgTask: Feb 04 15:16:08.177: Skipping EAP-Success to mobile
*dot1xMsgTask: Feb 04 15:16:08.177: Starting key exchange to mobile , data packets will be dropped
*dot1xMsgTask: Feb 04 15:16:08.177: Sending EAPOL-Key Message to mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.185: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.185: Received EAPOL-key in PTK_START state (message 2) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.185: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.185: Sending EAPOL-Key Message to mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.189: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.189: Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: apfMs1xStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: L2AUTHCOMPLETE (4) DHCP required on AP vapId 3 apVapId 3for this client
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: apfMsRunStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: RUN (20) Reached PLUMBFASTPATH: from line 4864
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  IPv6 Vlan = 99, IPv6 intf id = 14
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: Key exchange done, data packets from mobile should be forwarded shortly
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.190: Sending EAPOL-Key Message to mobile
*pemReceiveTask: Feb 04 15:16:08.190: Added NPU entry of type 1, dtlFlags 0x0
*spamApTask0: Feb 04 15:16:08.192: Sent EAPOL-Key M5 for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.201: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.201: Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:16:08.201: Stopping retransmission timer for mobile
====== Second one :The WGB has left the WiFi area (disassociated)  ==================
Interface........................................ vlan99
VLAN............................................. 99
Access VLAN...................................... 99
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 198314
      Number of Bytes Sent....................... 29425
      Number of Packets Received................. 1601
      Number of Packets Sent..................... 120
      Number of Data Retries..................... 71
      Number of Duplicate Received Packets....... 116
      Radio Signal Strength Indicator............ -92 dBm
      Signal to Noise Ratio...................... 5 dB
--More-- or (q)uit
      CGJP-WiFi-0006-En(slot 0) .................
antenna0: 1 seconds ago -91 dBm.................. antenna1: 1 seconds ago -94 dBm
      CGNO-WiFi-0004-Pl(slot 0) .................
antenna0: 142 seconds ago -93 dBm................ antenna1: 142 seconds ago -92 dBm
AP Name.......................................... CGJP-WiFi-0006-Entretien
Connected For ................................... 135 secs
Association Id................................... 67
--More-- or (q)uit
Current Rate..................................... 5.5
--More-- or (q)uit*apfMsConnTask_0: Feb 04 15:17:38.555: Deleting the client immediatly since WLAN is changed
*apfMsConnTask_0: Feb 04 15:18:30.565: Reassociation received from mobile on AP
*apfMsConnTask_0: Feb 04 15:18:30.565: Received association request from a work-group bridge (WGB)!
*apfMsConnTask_0: Feb 04 15:18:30.565: RUN (20) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1621)
*apfMsConnTask_0: Feb 04 15:18:30.565: Applying site-specific IPv6 override for station - vapId 3, site 'default-group', interface 'vlan99'
*apfMsConnTask_0: Feb 04 15:18:30.565: Applying IPv6 Interface Policy for station - vlan 99, interface id 14, interface 'vlan99'
*apfMsConnTask_0: Feb 04 15:18:30.565: STA - rates (8): 130 132 139 12 18 150 24 36 48 72 96 0 0 0 0 0
*apfMsConnTask_0: Feb 04 15:18:30.565: STA - rates (11): 130 132 139 12 18 150 24 36 48 72 96 0 0 0 0 0
*apfMsConnTask_0: Feb 04 15:18:30.565: Processing WPA IE type 221, length 24 for mobile
*apfMsConnTask_0: Feb 04 15:18:30.566: apfMsRunStateDec
*apfMsConnTask_0: Feb 04 15:18:30.566: apfMs1xStateDec
*apfMsConnTask_0: Feb 04 15:18:30.566: RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Feb 04 15:18:30.566: START (0) Initializing policy
*apfMsConnTask_0: Feb 04 15:18:30.566: START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Feb 04 15:18:30.566: AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Feb 04 15:18:30.566: Removed NPU entry.
*apfMsConnTask_0: Feb 04 15:18:30.566: 8021X_REQD (3) DHCP required on AP vapId 3 apVapId 3for this client
*apfMsConnTask_0: Feb 04 15:18:30.566: Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Feb 04 15:18:30.566: 8021X_REQD (3) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*apfMsConnTask_0: Feb 04 15:18:30.566: apfPemAddUser2 (apf_policy.c:223) Changing state for mobile on AP from Associated to Associated
*apfMsConnTask_0: Feb 04 15:18:30.566: Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_0: Feb 04 15:18:30.566: Sending Assoc Response to station on BSSID (status 0) ApVapId 3 Slot 0
*apfMsConnTask_0: Feb 04 15:18:30.566: apfProcessAssocReq (apf_80211.c:5241) Changing state for mobile on AP from Associated to Associated
*dot1xMsgTask: Feb 04 15:18:30.568: Creating a PKC PMKID Cache entry for station (RSN 0)
*dot1xMsgTask: Feb 04 15:18:30.568: Initiating WPA PSK to mobile
*dot1xMsgTask: Feb 04 15:18:30.568: dot1x - moving mobile into Force Auth state
*dot1xMsgTask: Feb 04 15:18:30.569: Skipping EAP-Success to mobile
*dot1xMsgTask: Feb 04 15:18:30.569: Starting key exchange to mobile , data packets will be dropped
*dot1xMsgTask: Feb 04 15:18:30.569: Sending EAPOL-Key Message to mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.578: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.578: Received EAPOL-key in PTK_START state (message 2) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.578: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.578: Sending EAPOL-Key Message to mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.583: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.583: Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.583: apfMs1xStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.583: 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: L2AUTHCOMPLETE (4) DHCP required on AP vapId 3 apVapId 3for this client
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP vapId 3 apVapId 3
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: apfMsRunStateInc
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: RUN (20) Reached PLUMBFASTPATH: from line 4864
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  IPv6 Vlan = 99, IPv6 intf id = 14
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: Stopping retransmission timer for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: Key exchange done, data packets from mobile should be forwarded shortly
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.584: Sending EAPOL-Key Message to mobile
*pemReceiveTask: Feb 04 15:18:30.584: Added NPU entry of type 1, dtlFlags 0x0
*spamApTask0: Feb 04 15:18:30.585: Sent EAPOL-Key M5 for mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.594: Received EAPOL-Key from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.594: Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile
*Dot1x_NW_MsgTask_6: Feb 04 15:18:30.594: Stopping retransmission timer for mobile
Hope the will help you to debug.
Best regards.
Abmas
Try the following WGB timer changes:
mobile station scan 1 6 11 ! note this should align with the available channels on WLC.
mobile station period 2 threshold 75
mobile station minimum-rate 6.0
Issue may be related to 1300 not resetting interface after so many association failures..
What does debug - debug dot11 dot11 0 trace print uplink - show?
Hi Adrian,
I issued the following commands :
AP1300_1(config-if)# mobile station period 2 threshold 75
I can only issue "mobile station period 2 threshold 75". I can not have other option than "period" in the "mobile station .... "
like "mobile station scan ..." or "mobile station minimum-rate ...."
Best regards.
Abmas
show version?
From memory, the latest IOS ver is 12.4.25d.  The prevoius ver 12.4.10b may not have additional WGB mobile station comands.
Some links I found for you...
Hope this helps
Adrian.
